    [Plugin] PSTv1.0 English Version (Updated Mar 26)
    34 Posts 16 Posters 37.5k Views 16 Watching
    • B
      bianhai
      English version is updated.
      copy Plugins,Resources to sketchup7 folder.
      copy PowerSuToolE.strings to SketchUp7/Resources/en-US sketchup7 folder.
      PowerSuToolE.strings is English Language.
      PowerSuTool(v1.01).rar
      • B
        bianhai
        This is the plugins Picture information.
        • MALAISEM
          MALAISE
          Thank you BianHai 👍 for us we poor non speaking chinese people 🤣
          MALAISE
            sepo
            Thanks...will give it a whirl.
              sepo
              I am getting jumbled info while using balustrade. The others seems fine. Like in particular punching holes, quite useful. There is also version of profile builder. Floor plate tool can be useful if you are designing tall buildings.
              • kenK
                ken
                OK, I have installed the plugin. However it is not English, it is still the chinese version.
                Thanks for what looks to be a usefull plugin.
                Ken
                  sepo
                  You got follow instruction ....so content of resources to resources, content of plugins to plugins and and en string within en-US . Took me while to work it out . Now I have everything in English but handrail tool.
                    Little bug! 😉
                    Buttons are inversed!
                      No its just that you don't place folders at the good place!
                      the folder US-en (from the plugin above) must be inside like this ...google7/Resources/US-en/US-en !!!
                      folder powerbarscript + file PowerBar_Load must be in the folder Plugins 😉
                      And all will work fine ☀
                      • coulteriC
                        coulteri
                        Does English work in Sketchup 6 ? I´m affraid it doesn´t....
                          just
                          Its working inside 6 also ☀ And see with also my French buttons 💚
                          the folder US-en (from the plugin above) must be inside like this ...google6/Resources/US-en/US-en !!!
                          folder powerbarscript + file PowerBar_Load must be in the folder Plugins 🤓
                          • coulteriC
                            coulteri
                            It doesn´t work. I have Powerbarscripts folder and Powerbar_load.rb in PLUGINS folder, PowerSuTool.string and PowerSuToolE.string in RESOURCES/EN-US folder. What´s wrong?
                              Are you sure to have this "double folder"?
                              ...google6/Resources/US-en/US-en/PowerSuTool.strings
                              PowerSuToolE.string must don't exist! I have not that!
                                sepo
                                PowerSuToolE.string should be in Resources and PowerSuToolE.string in En-Us within Resources
                                • coulteriC
                                  coulteri
                                  I realy don´t know, how to install it. I have tried anything, but it is not in English and it doesn´t work properly - it makes errors and doesn´t build walls. Is there anybody kind enough to write it for me step by step please? Thanks a lot.
                                    sepo
                                    Content of Plugins into plugins folder...so you have folder called PowerBarScripts and PowerBar_Load.rb in Plugins,
                                    PowerSuTool.strings goes into Resources. In resources now you have that file and en-US folder.
                                    PowerSuToolE.strings drop in en-US folder within Resources.
                                    As I said all is in English but balustrade and all seems work no problem.
                                    • coulteriC
                                      coulteri
                                      Don´t know why, but doesn´t work. It´s in English now, but it makes errors. When I´m trying to make a wall, it draws only lines and then nothing or makes Sketchup to crash. Mysterious.
                                        sepo
                                        which walls are you suggesting...there is no wall tool in this tool bar. Draw normally wall as you would and try to punch the hole.
                                        • G
                                          gerbaux
                                          thankz!! i'l give it a go when i got home!!! 😍
                                            Dan
                                            Thanks for this useful plug in, bianhai!
                                            A correct install doesn't need "PowerSuTool.strings" file, IMHO. That's the Chinese language string, as far as I could see.
                                            Unfortunately, there are still settings written in Chinese (handrail settings, some warning messages, the "about" window)
                                            Anyways, nice plug in, thanks again!
                                            Regards!
                                            Dan
