    Layer manager problems
    12 Posts 3 Posters 1.1k Views 3 Watching
    • L
      lundon
      I'm getting the same error message as toponypy and I am on Windows XP. Is this compatable with SU V7?
      I originally installed the French version by mistake, and did NOT get the error message. I do not see anything unusual in the French folder.
      Don
      • T
        toponypy
        thanks Chris,
        problem solved!
        Tony,
        Sketchup artist
        [url]http://
        about.me/tony.doutreligne/[/url]
        • L
          lundon
          Please share- how was it solved. I had the same problem.
          • T
            toponypy
            hi Lundon,
            I'm on Vista, so I did what Chris suggested, and it worked.
            If you're on Vista, navigate to your plugins folder. There will probably be a button in the top toolbar called "Compatibility Files". Click on it to find a "secret directory" that is also acting as your plugins folder.
            Tony,
            Sketchup artist
            [url]http://
            • Chris FullmerC
              I hate compatibility folders. I've been writing ruby scripts and find that my notepad++ struggles with saving to the true plugins folder, so it often saves it to the compatiblity folder. Then I'll have an old version inside my plugins folder, and the real version inside the compat. folder. It sure makes it hard to know what file I am actually working on, and which is actually being loaded by SU.....GGRRgrrr!
              Glad you figured it out and it helped,
              • L
                lundon
                Darn. I'm on XP, yet I got the same error as noted in the first post.
                • Chris FullmerC
                  Looks like it is trying to load a file from this location
                  Plugins/Layer Manager/layer_manager_v6_non_crypte.rb
                  Make sure that you have that folder and that file inside of it. If not, you've got it installed incorrectly. Perhaps that file is within the main plugins folder. If so, make a folder named "Layer Manager" and then place the file "layer_manager_v6_non_crypte.rb" into it.
                  Does that help?
                  • L
                    lundon
                    Thanks, Chris- but that file is not in the original zip file, let alone in my folders. I even downloaded and looked in the French version and V5 of the English version.
                    (The only thing in the Layer Manager subfolder is layer_manager_v6.rb and 36 png files.)
                    Could I have gotten it from the wrong place? I downloaded it from the ruby library depot (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm)?
                    • Chris FullmerC
                      Hm, that is probably the correct place to download it from. I am guessing he named something wrong. Try renaming the file in the folder to layer_manager_v6_non_crypte.rb That might just mess it up, but it might work.
                      • L
                        lundon
                        That's what it was!
                        Thanks, Chris.
