    Emitter problems
    4 Posts 3 Posters 718 Views 3 Watching
      Sgal
      I tried to create a slider-controlled emitter. In the "strenght" box I put this formula:
      slider('power')*100
      But the aspected "power" bar wasn't showed. The emitter started to replicate himself normally.
      Someone can help, please?
      problem.skp
        CPhillips
        Yup its a bug. Fixed in next release. Thanks Sgal!
          CPhillips
          Also:
          slider('power')*0
          Will result in a slider that doesn't do anything in that field.
          • W Offline
            Wacov
            Oooh, looks like we got us a bug! It doesn't make the slider! If you force sketchyphyics to make the slider using another box, it works... turn on the object's thruster setting, and use Chris' code, so that the thruster has no effect.
            Wierd...
