π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Emitter problems
I tried to create a slider-controlled emitter. In the "strenght" box I put this formula:
slider('power')*100But the aspected "power" bar wasn't showed. The emitter started to replicate himself normally.
Someone can help, please?
Yup its a bug. Fixed in next release. Thanks Sgal!
Also:
slider('power')*0Will result in a slider that doesn't do anything in that field.
Oooh, looks like we got us a bug! It doesn't make the slider! If you force sketchyphyics to make the slider using another box, it works... turn on the object's thruster setting, and use Chris' code, so that the thruster has no effect.
Wierd...
