    Helix
    13 Posts 7 Posters 1.8k Views 7 Watching
    • boofredlayB
      boofredlay
      A bit of playing around with Vray.
      • E
        Ecuadorian
        Looks cool, but... what's up with the faceted reflections? Was that on purpose?
        -Miguel Lescano
        • boofredlayB
          boofredlay
          Well I did not make the helix "tight enough" 😒
          • E
            Ecuadorian
            But... Well, I don't know V-ray, but there must be an option somewhere for "smoothing" reflections without adding geometry. At least every renderer I've used for the last 7 years has had that option.
            -Miguel Lescano
            • boofredlayB
              boofredlay
              If so I have not reached that point in the manual yet 😉
                sepo
                Read somwhere it is bug in Vray. Apparently explode and group again get rid of the problem.
                • tinanneT
                  tinanne
                  Looks great Boo... reminds me of a doughnut. MMM, I must be hungry or it's been a long time since I've had a doughnut. Probably both!
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                    ScottPara
                    yes, Vray does not like groups or components with nested groups too well. A bit of a bug. You can try exploding it but I think Eric said it better when he said the mesh was not as tight as it probably should have been for such a close shot. Ahhh...the Vray manual (aka...NOT the missing link)
                    Scott
                    Love the fact that some HATE my avatar.....
                    • boofredlayB
                      boofredlay
                      Incidentally, I did explode the helix and regroup and it rendered smooth as marble. Thanks.
                        silver_shadow
                        hI guys
                        Vray work fine in groups.
                        Build what you want, texture it, save the drawing..close it and re open it..and it will render fine with no missing elements.
                        The new vray also tend to facade curved surfaces, if that do happen to you, here is the solution.
                        Look at entitiy info, make sure the group has no material assign to it but only the faces.
                        If you assign a material to a group and its curved, it will unsmooth it.
                        hope this helps ☀
                        You can test it by building 2 columns. group both. Put a texture to the group and for the other one a texture to the surface. You will see the result.
                        • boofredlayB
                          boofredlay
                          Thanks for the tips Jacques.
                            devincig
                            Oh ! Funny ! I thing it will be better with more Smooth modeling !
                            http://www.flickr.com/photos/8839214@N03/
                            • boofredlayB
                              boofredlay
                              Here is the helix with Thea.
