    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 24.1k Views 14 Watching
    • N Offline
      NorviewsVeteran
      That's not really working though- if you lift it up and set it to static, just the wheel with the motor turns, everything else just kind of chills.
      //This_Is_All(I)+=Know()About.Code;
        phy
        yeah i see what you mean
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          CPhillips
          I dont know enough about a differential to know if it is possible to build one in SP or not.
          Sorry that model crashes. It has something to do with the gears but I cant quite figure out what.
          • W Offline
            Wacov
            I know for a fact that differentials aren't currently possible in SP without actually making shapes that mesh together. Chris, this model shows what a differential is there for (power distribution), and how it's supposed to work... if more resistance is induced on either wheel, a differential allows the power to be shifted to the other wheel; in the model, the blue parts would connect to the wheels.
            Updated
            The animation shows how a real differential works, and the slider conrols how much 'resistance' there is on each side.(NOTE: It's not a simulation of a differential, and WILL NOT WORK in a dynamic model. There are no gears, just motors to show what the gears would be doing)
              CPhillips
              I should say that I dont know why the gears in SP dont work for a differential. Its probably some deficiency in the gears but I dont know what.
              • W Offline
                Wacov
                It's because when the object a gear is on is rotated, it doesn't affect the gear it's connected to; the connected gear is only affected when the gear moves in relation to the object it's attached to. Also, if one gear's object is rotated around the gear it's connected to, it has no effect; for a differential to work, it's crucial that this is fixed. Gears need to be far more dynamic if complex mechanisms like differentials will work.
                  phy
                  OK NorviewsVeteran is this what you want tell me if it is
                  Error 404 (Not Found)!!1
                  (sketchup.google.com)
                  • W Offline
                    Wacov
                    Sorry but I don't think that's it. If you hold one wheel still, the power should be sent to the other wheel.
                      phy
                      but wacov when you turn the buggy it does send the power to the other wheel and when you hold the one wheel it does send it to the other it jerks a little but when you turn the hidden geometry you can see that it is transferring the power
                      • W Offline
                        Wacov
                        Oh yeah! Sorry... I just grabbed one of the wheels, and it didn't stop, so it didn't look like it was working.
                        • W Offline
                          Wacov
                          The problem with this is that it only works through the cones physically moving each other; what's really needed is a way to use sketchyphysics gears to do it, so the parts don't have to be touching.
                            phy
                            cpillips i downloaded the mac beta 2 and it looks like it has sound in it. is that so
                            and is there a windows version. just wondering
                              CPhillips
                              That version has some serious bugs in it that we are trying to fix. Sounds wont exactly be in the next release. More like the one after that.
                                BTM
                                ...What I think he was talking about is the fact that, when the control pannel is selected, and you use keyboard input (w,a,s,d for the most part), the mac's "alert sound" goes off, and if the key is held, repeats. It can get quite annoying... 😄
                                ...If that's not what he was talking about, I might aswell have mentioned that anyways, even though you probably already knew about it.
                                  CPhillips
                                  I didnt know about that bug. I wonder why it would do that.
                                  But the version he is talking about does have some sound support. Not full on sounds. But you can play a sound when something happens.
                                    BTM
                                    By the way, doesn't he mean mac alpha 2? Or am I not keeping up with what's going on?
                                      BTM
                                        CPhillips
                                        Next version of both Win and Mac was going to be beta2. Now it looks like both will be Release Candidates.
                                          phy
                                          no i meant beta 2
                                            phy
                                            That is cool.
                                            • 2 / 4
