    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 26.2k Views 14 Watching
      CPhillips
      @norviewsveteran said:
      I'm having trouble with a rear differential, it seems that you can't have gears connected to each other when their hinges are in the same group. When I run the simulation, the gears don't mesh, and when I go to end the sim, it creates a bug splat. Is something wrong or am I doing it wrong?
      Post the model and I'll take a look.
        CPhillips
        @cray said:
        Is there a list of what controller fields are available? I have a logitech ATTACK 3 and it works with joy("lefty") and joy("leftx"). I want to assign the slider on the joystick. In old version of sketchyphysics it seemed to recognize it as rightx.
        No final list yet. But
        rightx,righty,leftx,lefty,joyLX,joyLY,joyRX,joyRY
        will continue to work for joystick and keyboard emulation until at least SPIV.
        The joystick button shortcuts:
        a,b,x,y
        work now. But I may remove them if I do a 3.x release. Those names (a,b,x,y) are just too common.
        To be future proof use the new syntax instead.
        joy("leftx")
        and
        joybutton("a")
        • N Offline
          NorviewsVeteran
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          //This_Is_All(I)+=Know()About.Code;
            phy
            you can try grouping the hinges with the wheels instead of each other
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
            • N Offline
              NorviewsVeteran
              That's a good idea, and after trying it a few times, still no luck.
                phy
                this is what i came up with see if it is what you want
                differential (3)1.skp
                  phy
                  I grouped the motor with the one wheel you tell me of it is what you want
                  • N Offline
                    NorviewsVeteran
                    That's not really working though- if you lift it up and set it to static, just the wheel with the motor turns, everything else just kind of chills.
                      phy
                      yeah i see what you mean
                        CPhillips
                        I dont know enough about a differential to know if it is possible to build one in SP or not.
                        Sorry that model crashes. It has something to do with the gears but I cant quite figure out what.
                        • W Offline
                          Wacov
                          I know for a fact that differentials aren't currently possible in SP without actually making shapes that mesh together. Chris, this model shows what a differential is there for (power distribution), and how it's supposed to work... if more resistance is induced on either wheel, a differential allows the power to be shifted to the other wheel; in the model, the blue parts would connect to the wheels.
                          Updated
                          The animation shows how a real differential works, and the slider conrols how much 'resistance' there is on each side.(NOTE: It's not a simulation of a differential, and WILL NOT WORK in a dynamic model. There are no gears, just motors to show what the gears would be doing)
                            CPhillips
                            I should say that I dont know why the gears in SP dont work for a differential. Its probably some deficiency in the gears but I dont know what.
                            • W Offline
                              Wacov
                              It's because when the object a gear is on is rotated, it doesn't affect the gear it's connected to; the connected gear is only affected when the gear moves in relation to the object it's attached to. Also, if one gear's object is rotated around the gear it's connected to, it has no effect; for a differential to work, it's crucial that this is fixed. Gears need to be far more dynamic if complex mechanisms like differentials will work.
                                phy
                                OK NorviewsVeteran is this what you want tell me if it is
                                • W Offline
                                  Wacov
                                  Sorry but I don't think that's it. If you hold one wheel still, the power should be sent to the other wheel.
                                    phy
                                    but wacov when you turn the buggy it does send the power to the other wheel and when you hold the one wheel it does send it to the other it jerks a little but when you turn the hidden geometry you can see that it is transferring the power
                                    • W Offline
                                      Wacov
                                      Oh yeah! Sorry... I just grabbed one of the wheels, and it didn't stop, so it didn't look like it was working.
                                      • W Offline
                                        Wacov
                                        The problem with this is that it only works through the cones physically moving each other; what's really needed is a way to use sketchyphysics gears to do it, so the parts don't have to be touching.
                                          phy
                                          cpillips i downloaded the mac beta 2 and it looks like it has sound in it. is that so
                                          and is there a windows version. just wondering
                                            CPhillips
                                            That version has some serious bugs in it that we are trying to fix. Sounds wont exactly be in the next release. More like the one after that.
                                            • 2 / 4
