    Object-Triggering
    4 Posts 4 Posters 641 Views 4 Watching
      Bigbjason
      I would like to see it where objects can trigger different events. Like a supermarket door, one that slides open when you step in front of it. You would have the door and an area set of in front of it. If you moved an object in that area, the door wold open. and stuff like that. Thing that would be possible? Then one could build different things that only do something if something else is done first, such as maybe a model must hit a button-thing and this would cause something else to happen.
        Physicsguy1
        if you mean in-sketchup triggering, one could have a forward floor connected to a spring. once a weight is detected there can be a straining motor joint that is released and completes one revolution, then returning to the original position after the platform has moved back up. if you could find some mechanism to open the door once the revolution has commenced, that would do it. i might upload an example
          CPhillips
          Not yet. But soon.
          • W Offline
            Wacov
            Something like the magnet switches from LBP could achieve all kinds of stuff like this; they're basically proximity switches. If we were able to use entity names within script, something like "if(proximity(box1,box2)<500);1.0;else;0.0;end" would do it. The way I've written that is probably stupid, but you get the idea... expanding on this, you could have sketchyphysics know an object's position in relation to the origin, something like "x/y/zproximity(origin,box1)", its x/y/z speed and how much it's pitch/roll/yawing. Also use joint names in script, like "0.5-hinge1000", for levers etc. If it's possible, that'd be awesome, if it's not, never mind.
