<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Object-Triggering]]></title><description><![CDATA[<p dir="auto">I would like to see it where objects can trigger different events. Like a supermarket door, one that slides open when you step in front of it. You would have the door and an area set of in front of it. If you moved an object in that area, the door wold open. and stuff like that. Thing that would be possible? Then one could build different things that only do something if something else is done first, such as maybe a model must hit a button-thing and this would cause something else to happen.</p>
]]></description><link>https://community.sketchucation.com/topic/110892/object-triggering</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 03:20:46 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/110892.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Mar 2009 01:16:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Object-Triggering on Thu, 19 Mar 2009 12:43:22 GMT]]></title><description><![CDATA[<p dir="auto">Something like the magnet switches from LBP could achieve all kinds of stuff like this; they're basically proximity switches. If we were able to use entity names within script, something like "if(proximity(box1,box2)&lt;500);1.0;else;0.0;end" would do it. The way I've written that is probably stupid, but you get the idea... expanding on this, you could have sketchyphysics know an object's position in relation to the origin, something like "x/y/zproximity(origin,box1)", its x/y/z speed and how much it's pitch/roll/yawing. Also use joint names in script, like "0.5-hinge1000", for levers etc. If it's possible, that'd be awesome, if it's not, never mind.</p>
]]></description><link>https://community.sketchucation.com/post/1076613</link><guid isPermaLink="true">https://community.sketchucation.com/post/1076613</guid><dc:creator><![CDATA[Wacov]]></dc:creator><pubDate>Thu, 19 Mar 2009 12:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to Object-Triggering on Thu, 19 Mar 2009 02:40:11 GMT]]></title><description><![CDATA[<p dir="auto">Not yet. But soon.</p>
]]></description><link>https://community.sketchucation.com/post/1076557</link><guid isPermaLink="true">https://community.sketchucation.com/post/1076557</guid><dc:creator><![CDATA[CPhillips]]></dc:creator><pubDate>Thu, 19 Mar 2009 02:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to Object-Triggering on Thu, 19 Mar 2009 02:13:46 GMT]]></title><description><![CDATA[<p dir="auto">if you mean in-sketchup triggering, one could have a forward floor connected to a spring. once a weight is detected there can be a straining motor joint that is released and completes one revolution, then returning to the original position after the platform has moved back up. if you could find some mechanism to open the door once the revolution has commenced, that would do it. i might upload an example</p>
]]></description><link>https://community.sketchucation.com/post/1076550</link><guid isPermaLink="true">https://community.sketchucation.com/post/1076550</guid><dc:creator><![CDATA[Physicsguy1]]></dc:creator><pubDate>Thu, 19 Mar 2009 02:13:46 GMT</pubDate></item></channel></rss>
