    Updated All my Scripts (literally)
    14 Posts 7 Posters 2.7k Views 7 Watching
      dylan
      Thats is so much neater, nice work.
      http://dmdarchitecture.co.uk/
      • boofredlayB
        boofredlay
        Thanks Chris, how very neat of you.
        • C
          chango70
          Sketchstatic!
          • Chris FullmerC
            Cool thing! πŸ‘ 😎
            You must also say to kill Greeble beta (cfl_Greeble)
            And that random painter works only on V7;
            Ah yes, clf_greeble.rb is obsolete now and can be deleted if you have it installed (which I noticed in one of your screenshots Frenchy that it was still installed). Just delete it. clf_greeble_2.rb is better (I hope).
            And I seriously broke random painter? I am the worst script writer ever. I think I break more than I fix. Ok, I'll look into it and hopefully get it working again shortly. Thanks for checking out my scripts,
            • Chris FullmerC
              Hmm, I am not seeing anything in random painter that should not work with version 6. Make sure you have the wxSU ruby installed in 6 and progressbar also (which I assume you have).
              • Chris FullmerC
                ok, I just tested random painter in su6 and it worked fine for me, let me know if you figure it out or if there is still a problem.
                • X
                  xrok1
                  i think it would be great if you put your whole updated toolset into 1 zip file for us to digest upon. πŸ˜„
                    Ok Random Painter works fine also in V 6 πŸ˜„
                    It was the wxu : I have believed that was an outside prog and that is should not installed twice! 😳
                    • RayOchoaR
                      RayOchoa
                      any way you could make a script that could allow the user to organize the plugins where they want?
                      CaR DeSiGnS bY mE
                      http://ray-ochoa.com
                      • X
                        xrok1
                        the million dollar question 🀣
                        • Chris FullmerC
                          Rick has already made a script that does that, and its pretty darn good. Its called organizer.rb. It is straightforward to use with easy scripts, but gets a little tricky when you have lots of very complex scripts. But the idea is that you install it, and then you create sub folders in the plugins folder and move all your scripts into those subfolders. Then each subfolder becomes a sub-menu of the plugins menu. Then you also must make make a list in a provided text file of all the folders it should not look at. So you don't want it to load things in folders that were created by authors.
                          I have written my scripts to be compatible with Ricks organizer. So if you move my script into a different subfolder (and have organizer installed), my script will load into the assigned sub-menu instead of my default submenu. I know his script is $6, but it is worth it if you want to organize scripts your own way. I hope that helps,
                          • X
                            xrok1
                            when will people learn. no-one will buy a script (specially a complex one) without so much as a screen shot (preferably a video) of functionality? i would love a script like this, and have actually had my pointer on the buy now a couple times, but... i have no idea if it works like i envision or 😳 gave someone $6 for garbage. and yes i realize its $6 but its the principle. i'd rather give it to you than someone who asks for money but couldn't be bothered to post a screen shot. i would further add that it should be a prerequisite of smustards that you can't sell a script without so much as a screen shot.
                            so Chris please make a visual menu system to group and place our icons in and i'll gladly give YOU my money instead. πŸ˜›
