    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 23.8k Views 14 Watching
      THX
        Conor
        Fantastic, as always. Keep it up!
          MrPlanet
          Erm.... I have a problem, the program says that you need to be an administrator to install this, well, i AM the administrator!
          I reject your reality and substitute my own.
            CPhillips
            Weird. Did you have any trouble with the last one? It should be the same installer.
              MrPlanet
              No problem with the last one, maybe it's just the parallels system i use.
                CPhillips
                What OS and version of Sketchup are you using. It might have to do with the fact that I now include a msvc.dll.
                • MALAISEM Offline
                  MALAISE
                  😍 , really more and more efficient...
                  Thanks 👍
                  MALAISE
                    MrPlanet
                    I use OS X 10, and i use SU 7 Pro.
                      CPhillips
                      Its probably the .DLL. Is anyone else having the same problem?
                        BTM
                        mac version posting how soon? Days?
                          snoxie
                          Yes, Mac Beta?
                            cray
                            I loaded sketchyphysics 3 beta and the help window displays I have version 2.0b1 loaded. Is this correct or did my install go bad?
                              CPhillips
                              Mac Beta, probably about a week.
                              And I forgot to change the version in the About box so it still says 2.0b1.
                                BTM
                                ....So is it okay to post my alpha models now, even without Beta? 😄
                                  CPhillips
                                  Yes. But you may want to change the watermark text so people don't get uppity.
                                  • N Offline
                                    NorviewsVeteran
                                    I'm having trouble with a rear differential, it seems that you can't have gears connected to each other when their hinges are in the same group. When I run the simulation, the gears don't mesh, and when I go to end the sim, it creates a bug splat. Is something wrong or am I doing it wrong?
                                    //This_Is_All(I)+=Know()About.Code;
                                      cray
                                      @cphillips said:
                                      Big changes in this release are emitters, keyboard support, lots of error checking, and a better organized UI.
                                      Error 404 (Not Found)!!1
                                      (sketchyphysics2.googlecode.com)
                                      I'll make separate posts for the new features. Post general questions and bugs in this thread.
                                      Changes:
                                      Changed version to beta. No 3dwarehouse restrictions.
                                      Added emitters as a body property. FUN!
                                      Added more error checking on the simulation and formulas.
                                      Better handling of critical errors when the simulation is running.
                                      Should be much more stable now and will get even more stable as I get reports of errors.
                                      Added keyboard support with key("space") functions.
                                      Made joystick explicit with joy("lefty") functions.
                                      Made joystick buttons explicit with joybutton("a") functions.
                                      Removed some of the short names from the controller fields. a,b,x,y,rightx,righty,leftx,lefty, remain but may be removed.
                                      Added interface code to SketchyReplay to allow renders to call an export.
                                      BUG SketchyReplay doesnt recognize emitted objects.
                                      Updated installer to include the mscvr71.dll file.
                                      Cleaned up the UI
                                      -Added properties section
                                      -Added boarders around sections
                                      -Layout fixes.
                                      -Formula boxes are now blueish.
                                      -Some work on getting blur working on Mac. No luck yet.
                                      Added bulk "auto freeze" options to right click menu.
                                      Fixed bug in formulas with space and $
                                      Added every(number) keyword.
                                      Is there a list of what controller fields are available? I have a logitech ATTACK 3 and it works with joy("lefty") and joy("leftx"). I want to assign the slider on the joystick. In old version of sketchyphysics it seemed to recognize it as rightx.
                                        cray
                                        I tried other scripts and found joyRY is mapped to the Logitech ATTACK3 slider so I am running now. However if a list exists of the possible controls script variables/inputs, or a snippet of the source code, please point me to it. Thanks.
                                          CPhillips
                                          Post the model and I'll take a look.
                                            CPhillips
                                            No final list yet. But
                                            rightx,righty,leftx,lefty,joyLX,joyLY,joyRX,joyRY
                                            will continue to work for joystick and keyboard emulation until at least SPIV.
                                            The joystick button shortcuts:
                                            a,b,x,y
                                            work now. But I may remove them if I do a 3.x release. Those names (a,b,x,y) are just too common.
                                            To be future proof use the new syntax instead.
                                            joy("leftx")
                                            and
                                            joybutton("a")
                                            • 2 / 4
