    [Obsolete] LibFredo6 3.0e (newer version available)
    32 Posts 14 Posters 18.8k Views 14 Watching
      Aerilius
      Hello!
      I translated the plugin into german. I have to say that your library is a universal tool for developing/ translating scripts in infinite languages!
      libfredo6 v3.0e in german
      freescale v1.0e in german
        kava1222
        GOOOOOOOOOOOOOOOOOD
        • fredo6F Offline
          @tom2 said:
          Hello!
          Thanks very much Tom!
          I will integrate it in a next version of LibFredo6 and FreeScale, to be published soon.
          In between, any user can just drop the .lang files respectively in LIBFREDO6_Dir_30 and FREESCALE_Dir_10 folders. I tested that this works fine.
          Thanks again
          • gillesG Offline
            gilles
            Hello,
            I'm workink on mac OSX 4.11 SU 6;
            When I want to taper SU scratchs, here is my plugin folder what could be wrong?
            • fredo6F Offline
              Difficult to diagnose. Do you get a bugsplat? Did you try on simple cube?
              I suggest your turn the Ruby console on and tell if there any message.
              PS: By the way, you do not need to have folders LibFredo6_30e and FreeScale_10e
              • gillesG Offline
                gilles
                yes it was a basic cube ;
                I select it, select taper icon, choose a handle, move it to desire result then I release left click:" l'application à quittée inopinément "
                • X Offline
                  xrok1
                  @phxphun said:
                  Can someone tell me if this plugin can help me do this....
                  I have a French Door component (double-doors) that I want to modify to create a single door. I want to use just the door frame to make a narrower frame for my single door. I've removed both doors from the frame and need to scale the frame down to the width of a frame suitable for a single door.
                  When I use the SU Scale Tool to shrink the overall width, the sides of the frame become too narrow (the width of the frame's walls scale smaller as I make the overall frame narrower across the top).
                  I've installed FreeScale but I don't understand how to use it to do this. I'm getting the same result as with the SU Scale tool.
                  i know this is a late answer and probably dosn't matter anymore but... if you drag select the edges along one side of the frame ,then just move them in, this should solve your problem.
                  • fredo6F Offline
                    Can you check you installed version 1.0e for FreeScale and 3.0e for LibFredo6.
                    Do you see the wireframe when tapering?
                    Otherwise, no idea what it could be. I need other Mac users to tell if they have some clue, based on your version of OS and other considerations about the secret of Mac installation.
                    • gillesG Offline
                      gilles
                      yes for all;
                      I turn on ruby windows but nothing appears and SU scratch immediately when I release left button on tapering.
                      • Jean-FrancoJ Offline
                        Jean-Franco
                        The plugin is maybe interfering with another one ? To be sure, you can clean up (copy and save first) your Plugin directory and run only with Fredo's plugin. Then if it works OK, copy back your other plugins one by one or 5 by 5 until SU crashes again. Just idea.
                        Jean-Franco
                        • McGyverM Offline
                          McGyver
                          Thanks a million for the LibFredo6 3.0e fix, I just installed it and I can see the menu and icons now!! I'm on a Mac and some Rubies don't work too well on them, but I was so interested in your FreeScale tool that I had to come back to check and see if anything new had been posted about/for it. SCORE!! I'm really happy and can't wait to start using this tool!! Thanks again for making this awesome tool available and sharing your talents and hard work with everyone!! You rock Fredo6!! Really COOL!
                          Visit My ShareCG Freebie Gallery
                            ankry
                            NICE !!! THNKS FOR UPDATE...
                            • 2 / 2
