    Layers in woodworking projects
    18 Posts 5 Posters 4.5k Views 5 Watching
      PKast
      Very nice cabinet. Well done and it has nice interesting texture, almost looks like reclaimed pine.
      Best,
        brandy20
        This is the texture I used.
          Very nice. Thank you for sharing that.
            brandy20
            It's my pleasure
              brandy20
              Best,
              This is the link where I found this texture http://www.cgtextures.com/
              Anyway check this post to have many other ones
              301 Moved Permanently
              (www.sketchucation.com)
              cheers!
                Sawduster
                I've seen furniture pieces where each individual part is on its own layer. I don't go anywhere near that far, but when you do complete detailed drawings of all joinery and drawer webs and the like, being able to get stuff out of the picture while you work on it is extremely advantageous. It is also great for showing views of these internal parts. The Kneehole Desk I posted a bit ago is an example of how I generally work with layers.
                May all your dimensions be the sum of their total.
                Jerry
                http://www.sawdustersplace.com
                  Hi Jerry,
                  You might find it helpful to check out the link in my first post in this thread. Nice looking knee desk.
                    Sawduster
                    Well, that caused another change to the way I am used to working. I've been building components on the final layer on which they will be placed rather than on the 0 layer, then moving them. Might be why I sometimes end up with some extraneous geometry at the intersection of components when I do the first explode/implode of a model.
                    Jerry
                      Could be.
                      It's probably why you also have things disappearing when you don't want them to.
                      These are screen grabs from your desk. Notice what is missing and which layer is turned off.
                      http://img.photobucket.com/albums/v506/weekender410/Jerrys Desk/BackLayerHidden.jpg
                      It's hard to read in these small images but this first one is with the layer called Back turned off.
                      http://img.photobucket.com/albums/v506/weekender410/Jerrys Desk/FaceFrameLayerHidden.jpg
                      This is with the Face Frame layer turned off.
                      I'm not picking at you with this, Jerry. This is the sort of thing that can happen to anyone if they aren't handling layers correctly in SketchUp. Actually, I've seen much worse. Fortunately there's a plugin that will move all geometry back to Layer 0 where it belongs. Very useful for correcting that problem although if your components are put on the wrong layers, you'll still have to fix that manually. I'll see if I can find the link to the plugin.
                        Here's the link.
