    Purging Materials
    5 Posts 4 Posters 645 Views 4 Watching
    • Z Offline
      zzzSPUDzzz
      Hey,
      Can anyone tell me if there is a good plugin for purging materials in sketchUp, I know there is a purge tool but it doesn't seem to work that well.........thanks
      zzzSPUDzzz πŸ˜„
      • Z Offline
        zzzSPUDzzz
        Hey,
        OK so I had a bit of time and I searched through the forum and found what I was looking for, here is a link for anyone else
        who might be looking for the same thing, plugin works great so thanks to TIG who created it, nice one............ πŸ˜„
        301 Moved Permanently
        (www.sketchucation.com)
        zzzSPUDzzz
          gypsy46
          I've tried that rb...it doesn't work for beans. I even used a script to remove all materials from the existing model so I could clean up the file...then attempted every purge in the book...none removed the lengthy list of materials in the model. I can remove them one at a time, but that would take an eternity...anyone have any better idea?
            I've been using TIG's Purge All since it came out. Works fine for me. Are you sure you have it installed in the right place with the .rb extension?
            It's one of the most used plugins in my collection.
            • Chris FullmerC Offline
              It sounds like Gypsy wants a purge script that removes the used materials as well as the unsued. This is no longer a purge really. Purgeing generally refers to removing UNUSED materials. So if you are running TIG's purge_all script wanting it to remove materials that are being used by the model, it won't do that. Thats just not what its supposed to do.
              Instead, keep following the thread posted in that second post above and there is a link to smustard's remove materials plugin. That will go through and remove all materials from your model and then purge them from the materials list.
              EDIT: actually it looks like that script just removes them from the model. You will then need to purge them yourself.
