    Dynamic Window Set Available.
    4 Posts 4 Posters 1.2k Views 4 Watching
      Phillip
      Here is a link to a window set for Picture, Awning, Hopper, Casement, Hung, Dual Casement, Sliding and Louvre Dynamic Component windows. Included is a back plane cut-out Dynamic Component that once placed behind the window can be moved and stretched from the front wall plane.
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      Each window can also be placed in a pre cut hole in a wall.
      Size the window “Wall Thickness” setting to the frame depth. Cut the hole in the wall. Place a grouped plane recessed in the hole. Stick windows on the group plane. Erase or hide the recessed group plane.
      The window frames are slabs with holes cut in them rather than the usual corner blocks, top, bottom and sides. These examples demonstrate the inclusion of a subtractive synthesis approach to design combined with the more usual additive synthesis approach. SketchUp Push-Pull allows both.
      " - USE AT YOUR OWN RISK - "
      • H Offline
        huyvuvn
        very good stuff man 😄
        happiness on the way, not in the destination.
          Thanks Phillip for this (and all previous) contributions! I can see that we don't appreciate it as much as it would (should) deserve. I personally do not use many pre-made components for my profession but I'm sure they will be very useful once people get used to dynamic components enough.
          Thanks again (and yes, these are all great stuff!) 👍
            Ross Macintosh
            Big thanks Philip!
