    Greeble Beta (Updated Feb-06-2009)
    69 Posts 15 Posters 13.0k Views 15 Watching
    • T
      todd burch
      What, no WebDialog user interface??? Chicken!!
      Very nice work indeed Chris!!! Very nice. You can implement ProgressBar.rb and you'll satisfy Pilou. It's real easy, instructions are on Smustard with the script.
      Todd
        โ˜€
        Ps Seems to me there is a big bug ๐Ÿ˜„
        After use the Super Greeble, grouping this one, the Move, Rotation with copy don't work for the greebled object or for any other object!!! ๐Ÿ˜ฎ
        Curious that don't make that at each time but sometime ๐Ÿ˜ฒ
        After the * only one group is created and it is re-centered like the first!
        • Chris FullmerC
          ๐Ÿ˜ž, yeah I know this version right now has bugs. I made the mistake of updating it thinking I had all the bugs worked out. Then I found some problems and realized I did not have a backup copy of the older version - oops! So give me some time and I'lkl get a more stable version up, but I might have to revert a few features.
          @Todd the progressbar.rb is a great idea. I was a little overwhelmed thinking about making an hourglass cursor and stuff, but progressbar sounds like a great option!
          • Chris FullmerC
            Interesting. It should not happen. Would you mind trying again with this new version I just finished? It now supports (requires) progressbar.rb from smustard and it also supports a min/max offset value. I think its kind of confusing, but I'll leave it in because it is sort of cool what it allows you to do. But to get decent results, the first offset # should be closer to zero than the second offset number. Or set them both to zero for no offset or both to -10 for an even -10 offset on all faces. And remember, that negative numbers will make an inset face, while positive numbers will offset a larger face. It might be time to update my beginning video now. Thanks for testing everyone!
              Another thing ๐Ÿ˜‰
              Is that normal on a Tin surface all facets are selected but all facets don't be greebled โ“
                Thank you sir Malaise! โ˜€
                I will take care next time ๐Ÿ˜‰
                  Sorry but nothing works with this last version ๐Ÿ˜ฎ ( maybe because i am in cm and your written in inch ?)
                  Have you somewhere an old version because I have yet a version that not working now ๐Ÿ˜’
                  (I have not made a saving one of the previus ๐Ÿ˜ณ
                  I must go back to Protrude ๐Ÿ˜„
                    Jim
                    Partly due to the outrage expressed in this thread, I've decided to dis-allow posting of other people's scripts. A script author needs to be able to control which version of the script is available, and where it is posted.
                    • MALAISEM
                      MALAISE
                      Hi Pilou
                      here is the first version
                      MALAISE ๐Ÿ˜‰
                      [removed attachment] -- Jim
                      La Connaissance n'a de valeur que partagรฉe
                        johnsenior1973
                        There's a huge difference between someone helping another member out by posting an earlier version that worked for them and someone who's collecting other people's rubies and charging money for them.
                        Chris said, on this page: yeah I know this version right now has bugs. I made the mistake of updating it thinking I had all the bugs worked out. Then I found some problems and realized I did not have a backup copy of the older version - oops!
                        • GaieusG
                          Okay John, I guess Jim would like members to follow these guidelines applying common sense of course.
                          • MALAISEM
                            MALAISE
                            No problems Folks.... I understand. ๐Ÿ˜„
                            MALAISE
                            • Chris FullmerC
                              Oh dear, go to bed and all heck breaks loose ๐Ÿ˜„
                              I'll look at the script right now and see if its better. It sure run smoothly on my computer I was testing it on, so it definitely could be the metric problem. Thanks for the patience,
                              • Chris FullmerC
                                Well this is driving me nuts. I can see already that the version I uploaded is not the most recent version based on a few tweaks that are wrong. SO I'll go to the computer I was working on this on and see if it has the most recent. I did find a the spot that the script is breaking, and its in a spot that looks stable. Soooo, hopefully I'll find the working copy again and be able to upload that later today.
                                EDIT: for now, if someone wants to post an older working version, I wouldn't mind having a copy either ๐Ÿ˜„ But once I get the script working, I wouldn't mind it being removed.
                                  Take your time! โ˜€
                                  And a little trick ; when you develop : make some copy any time on any version on any supports!
                                  DD,DVD, Usb,Net etc...
                                  That can seems obvious but now your prog is only maybe less than 10 Kb so some easy to recover ๐Ÿ˜‰
                                  That will be not the case when you will have some megas of code! ๐Ÿ’š
                                  • T
                                    tomot
                                    Nice addition Chris!
                                    FYI: I just d/led this file. it works with SU 7 but SU6
                                    It might be better to simply post updated scripts in a zip or rar file that way the rar or zip will have a revision number you can always keep track of. Instead of simply changing the original post. Its just an idea I had.
                                    my plugins
                                    tomot
                                    • T
                                      tomot
                                      that should have read " FYI: I just d/led this file. it works with SU 7 butnotSU6"
                                      my plugins
                                      tomot
                                        that should have read " FYI: I just d/led this file. it works with SU 7 but not SU6"
                                        aaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhh ! ๐Ÿ˜ฎ
                                        ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                        โ˜€
                                          EDIT: If any Ruby coders are still following this thread, I am having problems that some greebles end up overlapping other faces and then delete faces that are queued to be greebled, then my script stops because it runs across a face that has been deleted. At least that is what I think is happening. So to solve that do I need to test each face to make sure it is not delete before I run the offset and push/pull?
                                          If you are trying to modify deleted objects then you should get an error in the console about that. If that's your problem then do a .valid? test on the entity you try to work with.
                                          I'm currently working on a script where I clean up the model, deleting lots of stuff and I've run into all sorts of problems as things shifts around when you delete entities. It seems the best is to loop over an array copy of entities which you've collected in before hand.
                                          • Chris FullmerC
                                            OK, so I'm getting some conflicting reports here (between my home and work computer). I've uploaded the most recent version. It works perfectly on my office XP, SU7 computer. I found a bug that caused SU6 to not work. It should now be working perfectly in 6. But it is not working on my home Vista SU7 machine. So if anyone has troubles with it now, let me know the SU version number and the platform. Thanks!
                                            • 2 / 4
