    Ask for a "flashing" feature.
    11 Posts 6 Posters 917 Views 6 Watching
    • MALAISEM Offline
      MALAISE
      Hi ruby's Masters (and Commanders)
      Would it be possible to make a small plugin that allows flashing ? Making an animation, I'm facing a small problem : in order to warn that X-ray is produced.
      I need to place a flashing symbol that is only displayed during the sequence. This could be apply to group or component. Of course many others purposes could be found..
      Thanks , because I'm still a poor ruby programmer 😕
      MALAISE
        Jim
        Something like this is possible...
        Here's the link: http://www.youtube.com/watch?v=WcCL7FqwFfk
        I just read a thread about embedding a youtube video and still can't do it!
          remus
          Call yourself a programmer!
          [flash=425,344:2vy0skzg]http://www.youtube.com/v/WcCL7FqwFfk&hl=en&fs=1[/flash:2vy0skzg]
            Jim
            I just checked your post to see how you did it and I swear I tried that...
              Daniel S
              [flash=648,480:2cnizyra]http://youtube.com/v/WcCL7FqwFfk[/flash:2cnizyra]
              This is the code for embedding a youtube video here in SCF:
              [flash=648,480]http://youtube.com/v/WcCL7FqwFfk[/flash]
              Daniel S
              • MALAISEM Offline
                MALAISE
                Thanks Jim, Remus and Daniel S for the posts
                I remember to have seen that video in the past...At the beginning we see that a flasher plugin is used. Where can we find it ? 😄
                MALAISE 👍
                  Galdor
                  You can find the flasher plugin here
                  Face Flasher
                  Just another experiment - in-model, timer-controlled material cycling. It seems UI.start_timer has a 1 second minimum. i.e. I couldn't get a...
                  (sketchuptips.blogspot.com)
                    Jim
                    Warning!
                    I hadn't looked at that plugin for a long time. I just notices that each time the color changes, the Undo queue gets shifted.
                    In short, this plugin will pretty much destroy your ability to perform undo operations...
                      todd burch
                      I'm probably the most ignorant person on the planet right now about Dynamic Components, but I'm thinking the flashing could be done with a DC.
                        remus
                        Todd, it would probably be quite easy to setup with a DC although im not sure if you could get it to keep going forever. I think it would have to be a time limited thing.
                        Jim, the only reason i can think of is that you didnt get the right URL for the video. You need to get the URL form the 'embed' box on the youtube page, NOT the URL you go to to watch the video.
                        • MALAISEM Offline
                          MALAISE
                          Hi All
                          Just a small trial using Morisdov's proper animation plugin and Jim's flasher plugin.
                          I notice the flashing face only supports flicker when entire ( no separate items painted with the same
                          color)
                          MALAISE 😄
                          flashbox.swf
