    Run windows .exe and wait for completion
    3 Posts 2 Posters 693 Views 2 Watching
    • Al HartA Offline
      Al Hart
      For the RpTreeMaker app I want to run a Windows .exe, passing it an argument, and wait for the execution to complete.
      We have been using system(command_line) for this, but as SketchUp waits, it uses up too many machine cycles.
      I tried Win32API and ShellExecute, but it doesn't wait.
      I tried UI.openURL(sexec), but couldn't see to get it to work with arguments.
      Does anyone have any other ideas?
      Al Hart
      IRender nXt from Render Plus
        Petruscaleus
        Well, I doubt this will be any help to you, but in simple batch file I would use the START command along with the parameter /WAIT
        start /wait yourprogram.exe <parameters you want to pass along>
        next_command (will be executed when yourprogram.exe has terminated)
        ...but perhaps you can use it somehow.
        • Al HartA Offline
          Al Hart
          I was finally able to do this using Win32API and a function I call "call_and_wait".
          def self;;call_and_wait(scommand_line)
          		cp_params = 'LPLLLLLLPP'
          		create_process = Win32API.new('kernel32','CreateProcess', cp_params, 'I')
          		startinfo = [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0].pack('LLLLLLLLLLLLSSLLLL')
          		# place holder for results
          		procinfo  = [0,0,0,0].pack('LLLL')
          		trace("scommand_line; %s", scommand_line)
          		cp = create_process.call(0, scommand_line, 0, 0, 0, 0, 0, 0, startinfo, procinfo)
          		trace("create_process returned; %s", cp)
          		if (cp == 0)
          			return
          		end#if
          		# get process if of process we created
          		hProcess = procinfo.unpack("LLLL")[0]
          		trace("hProcess; %s waiting...", hProcess)
          		if (hProcess == 0)
          			return
          		end#if
          		waitForSingleObject = Win32API.new("kernel32","WaitForSingleObject",['L','L'],'L')
          		a = waitForSingleObject.Call( hProcess, 0xFFFFFFFF ) # wait forever
          		trace("waitForSingleObject returned; %s", a)
          	end#def
          The WaitForSingleObject waits for the task to complete without using up resources.
          The ruby command system(command_line) runs the commands and waits for it, but uses up 1/2 of the resources of the machine in a tight loop checking to see if the command is done yet.
          Al Hart
          With your input, this post could be even better šŸ’—
