    Can sketchup do this
    7 Posts 6 Posters 5.4k Views 6 Watching
      cuteevil7
      hi all, im an architecture student and a sketchup user
      im modeling organic design and was wondering which kind of plugins allows me to do organic structure ..
      for example the sandbox and subdevide allow me to do traingles and rectangles shapes ... but whatf if i want other shapes ... ??
      here is a example
      http://www.maskinstorm.org/uploaded_images/whisper-712700-746514.jpg
      http://images.beijing2008.cn/20070808/Img214122910.jpg
      these example are somehow the way i want to model my design ... which plugins can be helpul to achieve that ?
        johnsenior1973
        To do that I'd use Subdivide and Smooth and FFD. I'd then use the group as a basic template on which to draw the structure. I'd then delete the group, then use line2cyl.rb from http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm .
          johnsenior1973
          Instead of using S+S and FFD to do the shape. You could also make the first shape with with the Bezierspline plugin and taper maker.
          • E Offline
            ELYSIUM
            Check this thread on pushpullbar:
            404 Not Found
            (www.pushpullbar.com)
            its a good source of info on how to design this type of structures.
              cuteevil7
              thank you guys for answers , 😄
              im not a biggner in sketchup im doin some intersting stuff in it ... so its okay with me to handle such issues... im just trying to find easier ways to model such things
                TopMod will be maybe also a cool solution for the structure 😉
                It's free ☀
                Interest is that you draw the "primary surface wire structure" then the prog calculates all intersections!
                You can import inside any object format obj then launch some crazzy functions!
                Then recall it in SU for make all that you want!
                By Meminesis Visionark
                Here a little try by me 😉
                http://forums.polyloop.net/imagehosting/1964946e1b4b30e9.jpg
                  danbush
                  The pushpullbar project linked to was actually developed in Rhino with Rhino-specific scripts so while some of the info will be useful, you will have to look elsewhere for your answer...
