    Ray Ochoa- My Car WIPs and final renders
    217 Posts 33 Posters 64.5k Views 33 Watching
    • F Offline
      FoXar
      Woah man, very nice car, I really like the front ๐Ÿ˜„
      Keep it up!
      • RayOchoaR Offline
        RayOchoa
        Thanks i am currently now away from my home computer and if anyone would like to render this car i would appreciate it alot
        CaR DeSiGnS bY mE
        http://ray-ochoa.com
          KDSDESIGN
          That file only took 26 seconds to download. lol
          Regards,
          โ–ˆKevinโ–ˆ
          (about 20% done)
            BTM
            I'm on it ๐Ÿ˜‰
            • RayOchoaR Offline
              RayOchoa
              Thanks BTM and once again i appreciate it
              CaR DeSiGnS bY mE
                BTM
                here's a medium-quality test: I can change anything you want with the setup, if you want something brighter, shinier, different lights, background, etc., don't hesitate to ask.
                back-side angle:
                front-ground angle:
                any other angles that you'd like?
                • RayOchoaR Offline
                  RayOchoa
                  I really like the first and last one the last one has the perfect angle but it would be nice if i could see the whole car. The 2nd one would be much better if the rear red lights were maybe lit on a little bit and if i could see more of the back end. Not wanting to get picky or anythin but i appreciate it and thanks
                  CaR DeSiGnS bY mE
                    BTM
                    I'm making a few more, with different settings, lights and edited textures. I'm changing the glass texture too, and now it's giving off a cool looking caustic reflection on the walls. I'll post it when it's done.
                    • FrederikF Offline
                      Frederik
                      What render app. are you using BTM..?? ๐Ÿ˜•
                      Cheers
                      Kim Frederik
                        BTM
                        Another render:
                        Frederik: I use Kerkythea (which you seem to be a team member of), why?
                        I make all my textures myself. I don't use the pre-made ones.
                        speaking of Kerkythea, how do you export as a flythrough animation as a video; I can only export them as images.
                        • FrederikF Offline
                          Frederik
                          Why...??? Well... I just am one of the KT Team members... ๐Ÿ˜‰
                          (In KT you can check the "Help" > "About Kerkythea" and you'll see my name in the credit list... ๐Ÿ˜‰
                          But you can also check out the credits online... )
                          But if you mean "why am I asking?" it's because I really like your renders... ๐Ÿ‘
                          Why not..??
                          Not that it matters really, but it's often so much easier to use some of the premade materials from one of the material libraries we've made available... ๐Ÿ˜‰
                          And that's the only way you can make the animation... ๐Ÿ˜‰
                          But once you've rendered all the images/frames, you just stitch them together to a video using i.e. VirtualDub or a similar program... ๐Ÿ˜‰
                          Please also see the Walkthrough Animation Step-by-Step tutorial... ๐Ÿ˜‰
                          Cheers
                          Kim Frederik
                            KDSDESIGN
                            also about the rendering....
                            When i make a texture, i cant seem to apply it. whenever i exit it doesnt apply. ive tried everything, cant find out how, my car paint isnt that good. plus when i try to apply one of the premade textures, it wont apply.
                            Regards,
                            โ–ˆKevinโ–ˆ
                            (about 20% done)
                              BTM
                              The first time I used KT, I had one of these issues too. You have to double click on the textures.
                              and when you edit them, you have to click "apply", not just exit the window.
                              an easy way to see when a textures is applied/change, is to go to View> Adjust> solid renderings. Your screen will show the model as textured, instead of wireframe.
                              Oh, question frederik: will any future versions of KT allow animated GIF exports?
                              • FrederikF Offline
                                Frederik
                                The short answer is no...
                                Besides, I don't see any reason for having such an ability, since you can - just like I explained above - take all the rendered images and convert them into an animated GIF, Flash or whatever format you prefer... ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                  BTM
                                  I know, but I can't seem to find anything like that for mac. I'll probably find one in a few days though.
                                  • RayOchoaR Offline
                                    RayOchoa
                                    My latest car im probably going to put it in a contest if you want to see it just click on the link here --> http://www.local-motors.com/checkupDet.php?c=1448
                                    http://www.local-motors.com/user_images/cr21409t.png
                                    CaR DeSiGnS bY mE
                                    • RayOchoaR Offline
                                      RayOchoa
                                      Some renderings
                                      http://www.local-motors.com/user_images/cr21621t.jpg
                                      http://www.local-motors.com/user_images/cr21629t.jpg
                                      http://www.local-motors.com/user_images/cr21625t.jpg
                                      CaR DeSiGnS bY mE
                                      • RayOchoaR Offline
                                        RayOchoa
                                        bump
                                        CaR DeSiGnS bY mE
                                          KDSDESIGN
                                          Ehhhhhh.... What Was That?
                                          Regards,
                                          โ–ˆKevinโ–ˆ
                                          (about 20% done)
                                          • F Offline
                                            FoXar
                                            WOah very nice work man!
                                            The renderings are getting better and better to although they could improve, you could try to use MLT, but really...
                                            Keep it up! Maybe you could get into car design one time :]
                                            Than I would love to buy one of 'your' cars xD
                                            Hehe..
                                            But anyways, very nice work! ;]
                                            Grats..
                                            FoXy..
                                            • 11
                                            • 5 / 11
