    Batch Convert .eps images
    28 Posts 6 Posters 1.2k Views 6 Watching
    • Roguer1R Offline
      Roguer1
      I want to turn the vectorial .eps file into a high-res .jpg image so I can use it in SketchUp for 3D modeling. A .eps file is useless to me otherwise.
      If IrfanView can't do that then I'll need another program to batch convert the images.
      Chris Fullmer, if you are able and willing to convert the images fine to how I need them can you convert the ones from the following file: http://xmdolg.bay.livefilestore.com/y1p2gygMqsEnKuNiI4ooxWLEo0vyx96jBw8fAs58ECdnbtZzsndLVpNnWeOaNhTjLITvIhk846GaOde48JGJljQZA/eps.zip?download
      Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
        Seems your orignal file are not "vectorial" but just pixels!
        A format EPS can mix Pixels and vectors but seems in this case your cars are not vectorial!
        • Roguer1R Offline
          Roguer1
          I have opend them in photoshop and resized them perfectly. They are made in coreldraw so they can be resized and keep perfect quality. I just need a way of batch converting them. IrfraView cant do it so i need something else.
            I can't believe that toshop CS2 can't make that for a lot of images if it's works for one image!
            • Roguer1R Offline
              Roguer1
              Photoshop CS2 just has a problem batch converting files. It isnt a well made plug-in. I dont currently ahve CS2 installed on my cmputer because it craped out a couple of days ago but when i gt it re-installed I will give you an example of what is happening.
                I have seen at last your files with Goshtview and increase them to 300 % but alas there no batch function inside 😒
                So your EPS files are real vectorial 😳
                • Chris FullmerC Offline
                  It is working for me in Photoshop. I'll do those in that file for now, and I can do the rest later if there are more. I'm writing a report right now though and I don't want to bog down my computer for hours. So maybe tonight I can do the rest. I'll let you know when they are done. Also, I set their pixel res to 300. Its makin 1921x3279. Is that too big?
                    Ok, nevermind. I changed them down to 1105x1846 and it is speeding up the process significantly. I'll upload them when I'm done.
                      ok, its uploaded here:
                      http://chrisfullmer.com/forums/390images.zip
                        I'd be interested to know if those files came out ok. I tried to download the entire archive from your earlier post and those links are not valid. If you need an ftp to put them on, pm me and I'll give you a temporary login to mine and you can upload it all there. Then I can finish processing them.
                        • Roguer1R Offline
                          Roguer1
                          Thanks soooo much for the conversion. I dont know why my photoshop wouldnt convert them.
                          This is what was happening when I was batch converting in Photoshop. It would convert the first one perfectly and all the rest would end up as just a conversion. No resizing and at low quality
                          JPG.zip
                          Those earlyer links are not valid anymore. I have removed them from my skydrive. I can re-upload them if you want me to.
                          I had a look at some of the blueprints, whooo, some a really poorly made!
                          Again, thanks all for your help.
                            If you put them back online I'll d/l them and convert them all for you. Just let me know where they are and I'll tell you when I've d/l'ed them so you take em offline if you'd like.
                            • Roguer1R Offline
                              Roguer1
                              I have deleted all the other files and a few other really pointless ones.
                              Here they are:
                              http://cid-4a6ec86d99895c84.skydrive.live.com/self.aspx/Public/EPS.part1.rar
                              http://cid-4a6ec86d99895c84.skydrive.live.com/self.aspx/Public/EPS.part2.rar
                              • 2 / 2
