    Sketchup + vue d'esprit: a condo called oasis
    12 Posts 8 Posters 2.0k Views 8 Watching
      matteo
      A project for a condo in Merano, south tyrol, Italy.
      The style is composite, with mediterranean influences.
      hire me: http://www.nonsolo3d.it/ !
      • honoluludesktopH Offline
        honoluludesktop
        Nice! Rendered with ?
        • E Offline
          ELYSIUM
          Nice renders!
          the redenderig engine is Vue esprit.
          "http://www.e-onsoftware.com/"
            honoluludesktop
            Got NO, Get it, thanks 🙂
            • marked001M Offline
              marked001
              second image is beautiful!
              http://www.revision21vis.com
              instagram: revi21on
              • DanielD Offline
                Daniel
                Matteo, was that first image post processed? It appears too bright, especially in conjunction with the very dark sky in the background. You might try adjusting the sun location. Also, all the vegetation is the same color - you might try adding some trees with darker green leaves. Your grass texture could use some improving - I've found the Closeup Groundpack from Cornucopia3D looks good for middle and background areas. Second and third images are very nice.
                My avatar is an anachronism.
                  mirjman
                  i would love to hear more about the compositing... are you throwing in raw sketchup exports? photoshop plants? some of the trees look 2d, which is a shame since vue is so good at vegetation
                    matteo
                    location: (as said) merano, north of italy, an alpine town with a really mild climate. it is a well known touristic place, where north and south can meet each other. we have snow and palm trees at the some time
                    project: the project is itself a little crappy - the bureaucracy here is too strong and you have to accept many compromises: my goal was to give it a mediterranean flair, like many old buildings here.
                    all the exterior views were drawn in sketchup. in this case, only the building was exported to vue d'esprit, while all trees are native of vue: the foreground shows some single tree objects, while the background is populated by ecosystems (a kind of fake vegetation between 2d and 3d, that saves you a lot of render time, lowers the poly count and fools your eye). the only exception are the shrubs, made with sketchup, to reduce further the poly count. The radiosity engine is killed by hi-poly objects and i don't have all that time to spend to make it perfect - another compromise.
                    @daniel
                    yes, the sky of the first image is dark because it's a dramatic scene with a rainy dark sky with some light beams that filter through the clouds and hit the building. it's a bit like a searchlight.
                    what i love of vue d'esprit is that you can create some non-photorealistic atmospeheres: it's more emotional, like in some impressionist pictures. the night scene is not realistic at all, but looks great to me.
                    otherwise, if my goal was to achieve some photorealism i would have chosen indigo as render engine.
                    i hope this clears some more about these renderings.
                    just ask if you want to know something more.
                    matteo
                    • EarthMoverE Offline
                      EarthMover
                      Looks great Matteo! What are you using for your hedges?
                      Content Creator at Skapeup
                        matteo
                        earthmover,
                        here is my hedge component:
                        301 Moved Permanently
                        (www.sketchucation.com)
                        matteo
                        • soloS Offline
                          If I may offer some advice/tips;
                          Vue comes standard with a Plant editor, however Vue 7 does have much better source plants to edit and play with.
                          Using your editor it's simple to make realistic hedges from stock bushes or by rescalling trees and using other plants leaf images or even your own.
                          The great thing about Vue's solid growth trees is they render fast in vue regardless of the amount you have or how thick and poly heavy they may be, the other thing is L.O.D (level of detail) the further away an object is the lower the level of detail needed for render and Vue seems to do this great.
                          You can create a basic shrub, then save it and using it again make a transitional one, mass them together to create hedges, even make curving hedges, or customised to your terrain/garden.
                          http://img184.imageshack.us/img184/1075/planteditorrc5.jpg
                          http://img184.imageshack.us/img184/2694/hedges1ak0.jpg
                          Sorry about cropped images, as recently this forum has been doing this to all my images, not sure what has changed.
                            matteo
                            solo,
                            that's quite pretty, but i fear it is an option of vue infinite only - or at least you have to buy the plant plugin for vue d'esprit.
                            Since all elevation plans are made with sketchup, in a b&w style, these hedges suit well both programs. Time is my biggest enemy.
                            Anyway thank you for your tip, that's something I have to learn better.
