    Warehouse WIP
    38 Posts 13 Posters 6.4k Views 13 Watching
    • DanielD Offline
      Daniel
      Thanks Eric/Pete for the texture.
      My avatar is an anachronism.
        Mannie
        Nice lookin buildings
          Ross Macintosh
          I like it too. It appears to communicate the design very well.
          Thanks for the asphalt texture. What technique did you use for the sky? It looks yummy.
          Regards, Ross
          • boofredlayB Offline
            boofredlay
            Thanks all.
            Jason, the bushes are from the Podium plant library. I think once I get the tree photoshopped in the final image (there is one just to the right in the plans) they will be less noticeable. However I will keep my eye on that thanks. The cars in the back, I did not add any reflection to them. Maybe a bit of PS touch up there too.
            Ross, the sky is from a landscape photo I had "lying around" my hard drive that I just placed in behind the scene.
            I did a night render from another one of the building's entrances a while back here. maybe you remember it?
            These buildings are huge. 8 of them, 7 measuring 900 feet long with the majority of openings being roll up truck doors. This is the only one with an "at grade" entrance.
              boofredlay
              Again, thanks to all who have helped out.
              Here is an update. The original image I posted is not in the set the owner wants so I am on to the others. Here is a shot of one of the middle entrances. Bit of a boring setup but it is what it is.
                ScottPara
                Actually I like it. It is a bit gloomy but it helps the lights show. Maybe some more definition to the wall materials. There is a bit of tiling in the darker grey material though.
                Good work.
                Scott
                Love the fact that some HATE my avatar.....
                  johnsenior1973
                  Pedestrians walking through the loading bays to get to the entrance? Not working for a very safety-oriented company then?
                    boofredlay
                    The personal vehicle parking is facing the building.
                    Thanks Scott. I believe before I deliver this image I will fix that tiling.
                      ScottPara
                      Eric,
                      I like the overhang but it seems like water would run right down it to the face of the door. Is that right?
                      Scott
                        boofredlay
                        Ha Ha Ha, good eye. First off I am not the designer on this job, just the cadd monkey.
                        We just changed that canopy yesterday. It used to have a built up roof with roof drains going through the building and the owner wanted to cut cost so out it went. There will be a drip edge along one of the panel joint lines towards the leading edge but I am sure some water will make it closer to the door. Actually I think it might change later to some prefab unit but for the renderings this will stay.
                          mateo soletic
                          Nice work Eric. 👍
                          Concept Illustrations
                            KDSDESIGN
                            Again, nice work 👍
                            Regards,
                            █Kevin█
                            (about 20% done)
                            • DanielD Offline
                              Daniel
                              Eric, nice renderings, even if you did forget the dock bumpers on the second image.
                                boofredlay
                                Thanks Daniel. I did not forget the bumpers because the owner is not furnishing them. They will be tenant fit-ups if required. Dock levelers might be added but for the rendering they are not to be shown. Good eye.
                                I am cooking another view right now... so far it is my favorite.
                                  boofredlay
                                  Next view.
                                  • DanielD Offline
                                    Daniel
                                    Looks great, Mr. Lay.
                                      sepo
                                      Eric...I see rapid love between Podium and you. Looking good.
                                        boofredlay
                                        Aw shucks guys 😳
                                          KDSDESIGN
                                          CANT SEE THE IMAGE! 😡 my computers fault >_<
                                          Regards,
                                          █Kevin█
                                          (about 20% done)
                                            ScottPara
                                            Great work Eric and I see you have fixed the tiling (looks good now). Is that a light leak in the awning 😉 Really nice work, very clean.
                                            Scott
