    Stuff Topic (Once "My Projects and W.I.P.s")
    567 Posts 31 Posters 29.5k Views 31 Watching
    • StinkieS Offline
      Stinkie
      @kdsdesign said:
      can we just stop these nasty votes? and ACCUALLY POST
      Errr ... maybe you should've given people only one voting option? That might've worked. 😄
      On a more general note: criticism helps you to get better. Whenever I post anything, I'm grateful for the "hey, that's nice!" type of posts, but I'm much, much happier with the ones that explain what could be improved. ☀
        KDSDESIGN
        what i mean is the votes were quite "rude" and there was no post 😞
        if there was 1 voting option IT WOULDnt be a poll lol
        BTM, i mean uhh Youll see what i mean
        P.S. i added a poll that cant be offencive unless someone chosses other and says leave
        Regards,
        █Kevin█
        (about 20% done)
          BTM
          ...see what I did? you set your poll to allow a person to vote on all of the above. 😄 So my vote is for you to make a sketchyphysics casino art apartment. you should change it to select up to 1 item, not 9.
          BTW, you should check out my "Some of my stuff..." page.
            KDSDESIGN
            i "can" but you couldnt get the model. my best model was a house but its 33 megabytes 😞
            Regards,
            █Kevin█
            (about 20% done)
              KDSDESIGN
              i "can" but you cant upload the model. my best model is a house but its 33 megabytes 😞
              what i meant to say 😛
              Regards,
              █Kevin█
              (about 20% done)
                BTM
                I don't know what my best model is, but I've had some over 15MBs. the map on my "some of my stuff..." page is 9.8MBs %(#808080)[(i'm trying to get it acceptable for upload by the warehouse, it still isn't working though.)
                A little bit of the model. More pictures on my page.
                (BTW, that sketchyphysics art casino apartment was a joke 😎 you should change it so we can only pick 1 of the options in your poll.)]
                BTW, DID you see my page? If you did, what did you rate it 😄
                  KDSDESIGN
                  i rated the top one (courtesy of IDONTKNOWWHATTHEHELLITSAIDITSHOWEDSQUARES
                  SOIPICKEDTHETOP) and dont try to read that above
                  Regards,
                  █Kevin█
                  (about 20% done)
                    BTM
                    Oh. You must not have all the fonts I have 😕 The top one is 5 stars, then 4, then 3, then 2, then 1, then a skull and crossbones. 😉 (That last one's just for fun)
                    just to check... can you see these? ♫ ♬ ♩ ♪ ☺ ★ █ ☠ ☣ ⚠ ☢ ⚡
                    (the first 4 are different music notes, then a smiley, then a star, then a square, skull & cross bones, bio-hazard, Warning sign, radioactive symbol, then a lightning bolt.)
                      KDSDESIGN
                      1st 4th and 5th i can see. it might be i am using 3dwh to view this 😛
                      Regards,
                      █Kevin█
                      (about 20% done)
                      • marked001M Offline
                        marked001
                        just build something cool that you want to build.... and start a new thread with it..and let this thing get buried!
                        http://www.revision21vis.com
                        instagram: revi21on
                          KDSDESIGN
                          Naw. i feel like keepin this
                          Regards,
                          █Kevin█
                          (about 20% done)
                            BTM
                            I actually kind of agree. This thread is getting way off-topic.
                              KDSDESIGN
                              Fix it with this next thing
                              P.S. all (most) of the buildings are going to wind up in a city project
                              WIP
                              Regards,
                              █Kevin█
                              (about 20% done)
                                marked001
                                city projects are fun 👍
                                http://img384.imageshack.us/img384/4626/block12050906adl6.jpg
                                http://img444.imageshack.us/img444/5461/block12050906bgn3.jpg
                                http://img384.imageshack.us/img384/3371/buildingfront101906xv4.jpg
                                instagram: revi21on
                                  KDSDESIGN
                                  they are. but the bad part is they are too big to upload. i want to add my 33mb house my 4mb casino 170kb garage 2mb apartment and 2mb restaurant (will be fixed)
                                  Regards,
                                  █Kevin█
                                  (about 20% done)
                                    BTM
                                    Post some pictures of you're house: I bet I can give you some pointers to lower the file size, I'm pretty good at that stuff.
                                    Tip one: if you haven't done it yet, go to window menu, model info, purge unused. That'd be the most basic of all.
                                      KDSDESIGN
                                      i havnt used the screenshot tool i can render it but it will take forever i will probely be dead before the render is finished my comp has like 1kb of ram (not that low but low)
                                      Regards,
                                      █Kevin█
                                      (about 20% done)
                                        BTM
                                        In sketchup, go
                                        File > Export... > 2D Image
                                          KDSDESIGN
                                          In sketchup, go
                                          thx
                                          Edited restaurant:Restaurant 2.png
                                          Regards,
                                          █Kevin█
                                          (about 20% done)
                                            KDSDESIGN
                                            another:
                                            something was wrong and it wouldnt go in the last post (file size was too big)
                                            Regards,
                                            █Kevin█
                                            (about 20% done)
                                            • 28
                                            • 29
                                            • 2 / 29
