    SketchUp API docs
    5 Posts 3 Posters 945 Views 3 Watching
      I've just begun to look at the Ruby part of SketchUp.
      But I'm wondering, where do you go for your references?
      From this page: http://code.google.com/apis/sketchup/ it links to "reference documentation" (http://code.google.com/apis/sketchup/docs/developers_guide/index.html) and "wiki-style documentation" (http://groups.google.com/group/SketchUp-Plugins-Dev/web/google-sketchup-ruby-api)
      The wiki appear to contain more info.
      For instance, the Face object:
      The wiki page (http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Face.html) list these methods
      all_connected,area, back_material, back_material= , classify_point, edges, followme, get_UVHelper, loops, mesh, normal, outer_loop, plane, position_material, pushpull, reverse!, vertices
      while the "reference documentation" only lists these:
      area, edges, followme, loops, mesh, normal, outer_loop, plane, pushpull, reverse!, vertices
      And none of them mention that you can use .material on the face. (just guessed it'd be there since I noticed there was an back_material.)
      And yet, on some topics I feels there's much missing. Such as position_material:
      position_material
      The position_material method is used to position a material on a face.
      Syntax
      face.position_material material, pt_array, on_front
      Arguments
      material - a Material object
      pt_array - an array of Point3d objects used to position the material
      o_front - true to position the texture on the front of the Face or false to position it on the back of the Face.
      Comments
      The pt_array must contain 2, 4, 6 or 8 points. The points are used in pairs to tell where a point in the texture image is positioned on the Face. The first point in each pair is a 3D point in the model. It should be a point on the Face. The second point in each pair of points is a 2D point that gives the (u,v) coordinates of a point in the image to match up with the 3D point.
      In this case, it doesn't explain what the difference between using 2,4,6 or 8 points is.
      So my question is: is there a different source of documentation? Is it just me that feel that the documentation is a bit sparse? From other types of scripting I'm used to more information than what I can find on the SU API.
      • Chris FullmerC Offline
        I'm also following this with interest. I often pretend that I will Ruby someday, but now that DC's are out, I have taken to them rather quickly and I am quickly seeing things I would like to do that is well out of their current abilities. Enter Ruby....but I also get lost in the docs as they stand currently.
        Is there supposed to be better, newer, shinier docs coming out for SU7 soon?
        (Hi Rick, Todd, and Tavi! I don't get into this forum to say hi to you guys very often...)
          bump?
            lenglel
            Yes, the documentation on this method is sparse, yet self-contradictory.
            From the explanation:
            "The second point in each pair of points is a >>> 2D <<< point that gives the (u,v) coordinates"
            From the example code:
            pt_array[1] = Geom:: >>> Point3d <<< .new(0,0,0)
            This is the point array I used in a call to position_material
            pt_array = []
            pt_array[0] = face.vertices[0]
            pt_array[1] = Geom::Point3d.new(0,0,0)
            pt_array[2] = face.vertices[1]
            pt_array[3] = Geom::Point3d.new(1,0,1)
            Apparently, the first two points set the location of the red pin, the next two
            set the green pin. I'm still working out the other two.
            This is the result I get from using the point array above...
            Textured from ruby plug-in
              The effect of how many sets you use are as following:
              1 set: The origin of the texture, width and height is taken from the material width and height
              2 sets: Origin and scale+alignment
              3 sets: Origin, scale+alignment, Skew
              4 sets: Origin, scale+alignment, Skew, Distortion
