    Woodworking tools in SketchUp
    52 Posts 27 Posters 29.7k Views 27 Watching
    • aadbuildA Offline
      aadbuild
      I have few sugestions, job sheduling by phase. e.g phase 1 footings, phase 2 piers, phase 3 beares and joists etc. automated wall numbering & window numbering would be useful. If you are yet to check out housebuilder.rb, this ruby has some powerful house building uses. If you need anither beta tester please let me know.
      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
      https://www.plusspec.com
      • Mike LuceyM Offline
        Mike Lucey
        Great idea Gidon πŸ‘ I'll be watching the progression with interest.
        Mike
          Jim57
          Wow, is this a wish list or what?
          I'm way into the idea of a board stretcher. Perhaps it could have better size controls as well. It would be nice to know what the final size is, not just the difference between original and final versions.
          I have a lot of trouble designing furniture in Sketchup because there is so little control of curves. How about the SU equivalent of Beziers? I also have a lot of trouble editing what I've done. Often I trash a work in progress because it's easier to start over than to edit. I'm sure the skill will grow on me, but as a newbie I find the learning curve starts easy but quickly gets steep, at least for anything with delicacy or intricacy.
          Another tool I would like to see is a Molding Maker. It would be a specialized hybrid of a components manager and a Follow Me Tool. From a library of cutters (negative shapes) or patterns (actual moldings) you could extrude shapes along lines. Store anything from casing patterns to panel raises to tabletop edges and apply them to selected lines. Ideally, you could control where the profile hits the wood by dragging the shape into the rough stock, thereby setting the depth and height of the cutter relative to the stock.
          And as everyone else here has said, put me on the list of beta testers!
          Icarus Furniture
          (www.icarusfurniture.com)
            Already exists in several plugins.
              Matt666
              Hi all !
              I gave an idea of a script here !
              Frenglish at its best !
              My scripts
                Sparky977
                Any progress on this by chance? Specifically, the "board stretcher" option. That would be tremendously helpful! It would be nice to be able to make a small section of door stiles and rails for any cope and stick pattern I use, and then just be able to stretch those into whatever size door I needed.
                  You can do this already, Sparky, using the basic SketchUp tools. A plugin would be nice for it but it is possible without. Now with SU7Pro, you could make dynamic components to do the same thing although the components wouldn't be very useful for a cutlist later.
                    Sparky977
                    Mind telling me how? πŸ˜„
                    I've been trying to figure out a good way, and everything I've tried has been extremely inefficient. The scale tool doesn't work for what I'm talking about, because it scales the edge profiles as well. I just need the length changed, not the scale.
                      Are you drawing the doors as five separate pieces? Assuming you are, here are the steps. Suppose you want to add 3" to the width of a door with a raised panel and cope and stick joints. Just for fun, we'll make the door 3" wider to the right.
                      1. Move the right hand stile 3" to the right.
                      2. Open the top (or bottom. Unless they are different as in a tombstone door, they should be instances of the same component) rail component for editing.
                      3. With the Select tool, drag a left to right selection box around the right end of the rail.
                      4. Get the Move tool and move the selected geometry 3" to the right.
                      5. Open the raised panel component and repeat steps 4 and 5.
                      Done.
                      If the rail you didn't open for editing gets lengthened at the opposite end from the one you did edit, you rotated the copy instead of flipping it. This means you'll also need to move one rail to align its ends correctly. If you flip or mirror the copy, you won't have that problem.
                      If you are using SketchUp for woodworking, you might find some useful stuff url=http://finewoodworking.taunton.com/blog/design-click-build]here[/url].
                        Sparky977
                        Done.
                        Sorry for taking this thread somewhat off topic. I am trying to do this, and I just can's seem to get it to work. I understand how the left to right selection box is supposed to only select whats on the edge you are selecting, but its not working for me. I have a custom door profile that I am trying to make work for a customer. Right now, the stiles and rails are 3" wide. I need to resize them to 3 3/8. Every time I try the left to right selection, it selects every surface and edge in the stile. This door profile is fairly straightforward on the inside edge, but the outer edge profile that the client wants is something I will have to get a custom knife made for, for my shaper. The client is a graphic designer, so he is pretty picky about how he wants this edge. Anyway, I'm wondering if the profile is screwing up the selection tool?
                        I am attaching the component, in case maybe its not just me screwing it up.
                        I had some other issues with drawing this profile to begin with, but I won't get into that here. I'm sure there are some things that I'm just not doing right with this program.
                        VK Door Stile.skp
                          I'll reply to you on this shortly via PM.
                          Dave
                            Scott, check your PMs. I did a short little video for you and gave you a link.
                              GUNAWAN W
                              Hello Gidon,
                              i'm not a pro woodworker, sometime i had to design a cabinetery/kitchen set that need a more detail like section cut, maybe this site can give some idea :
                              http://www.cutlistsoftware.com/cutlist_plus_features.html
                              or
                              http://www.cabinets-plus.net/cutlistmaker.php
                              but is just an idea πŸ˜ƒ it would be perfect if it can be implemented in this release πŸŽ‰
                              and please release a metric version πŸ˜„
                                There's already a cutlist plugin for SketchUp that works quite well.
                                  akigrimm
                                  I am working on a complete furniture development system myself 😳 . I dont have really so much time for that, but I have thought of quite a bit of details and also searched existing programs for what they can do.
                                  After my opinion there are three major goals to achief:
                                  1. Create a cutlist fast and easy and use this data for all your following work.
                                  2. Connect a faktura or database programm to your drawing so you can generate easily an offer for your client.
                                  3. Make a nice and professional presentation.
                                  What I want is a easy way to get a cutlist, since that is the base for everything else in the workshop and for my offer and a good looking presentation. May be with doord that open and all that. But dont go into details that you dont need for your work, since you know your business.
                                  Nice would be to work in projects with all the data that dont refer to the drawing but to the project with all that a crm prog does (letters, bills, offers, adresses, deliveries, invoice, calendar) and also a calculation modul. If these all work together my work gets a lot easier.
                                  With dynamic components I think that we will reach there a lot faster than in the past. But I need to explain maybe a bit more detailed:
                                  We're using a machine program on our CNC that lets you design standart cabinets only by parameters. That is good. But to get the cutlist we still have to write it by hand, and before that make a drawing and all the shit. And before we even start we need to write an offer for the customer and to do that we have to more or less guess or do the same work in advance. So start with parametric designing of furniture. From these dynamic drawings get the cutlist and import it in a spreadsheet or database. There you have defined times for your production(which by experience you correct) and you have easily the price of your product. If you start you printout the cutlist. Better not ones but for everymachine that you are using. For example: One list for the raw cutting of boards before planing them or as we do: we cut our boards (strandboards etc.) 10 mm bigger before formatting on the CNC. so you could have one list with final measurements and one with the raw measures.
                                  Export the rawcutlist to a optimizer for cutting boards and you willl have the exact amount of materials you have to buy. If these can be stored in a database with their price, youre there. You need to calculate the amounts of edging material and the amount of veneer and lack that youll need. To obtain that, you need to be able to tell su not only how a material should look like, but also what it really is. For example would it make no difference for SU if your cabinet is made of oak massive wood or laminated boardss with oak dekor. But you could guve that information when constructing the cabinet.
                                  If this information can be stored it doesnt at first affect the drawing but can be very useful to have later, and when you start your cbainet entering "Material: Oak, massive" You have it in all following steps. Plus if your customer asks "How much is it in laminated boards, you change only one detail (Hopefully) and get the alternative price.
                                  So you should have quite comfortable dialogs since you have to enter a lot of data for eache piece.
                                  Dimensions, core material, overlay material, edging material, which edges are laminated, how are the surfaces treated. And to generate a whole cabinet like that, you need even more. One thing that helps us:
                                  Less is more
                                  Dont create a system for every exotic kind of furniture that you will ever build but one for the 85 % average ones. You dont need to draw the joinery (my opinion) even when I deliver my furniture it doesnt seem to make a lot of difference to my customers, if the drawers have dovetails or no, as far as the price is correct.
                                  When you want to create a strechable cabinet you just use components and change these. So if you want a drawer stretched you build it in components and stretch them in their proper way. There should be no prob but dont try from the start to calculate every thinkable construction of a cabinet or table, but stick to one and then expand.
                                  Sorry I guess this gets rather long so I better stop now.
                                    There's already a good cutlist plugin though.
                                      brandy20
                                      I downloaded arcs.rb, do you mean this one or maybe another better one?
                                        No, I mean Bezier.rb for one. There's also BezierSpline.
                                          brandy20
                                          I installed it and read the tutorial. That's what I was looking for
                                            jhoutman
                                            Attached are some simple woodworking tools that I use all the time.
                                            They are simple, Create a board - (actually a named component with all three dimensions and oriented in space.
                                            Resize a board.
                                            Drill tool - drills any component
                                            Dado tool - creates a dado easily in any component.
                                            Bring component to front. Handy to create cutting list of components.
                                            Set component Relative. This moves a component relative to another.
                                            Handy for arranging boards in space.
                                            I have started on a component or group stretcher that allows one to resize
                                            say, a drawer, one direction at a time without screwing up the parts that
                                            shouldn't change.
                                            Thanks,
                                            • 2 / 3
