    What I didn’t know
    2 Posts 2 Posters 340 Views 2 Watching
    • kenK
      ken
      Yesterday, while reading “Google SketchuUp for Dummies”, I discovered that not only can you make a group from a section slice, which I knew, but you can also export a section slice as a DWG file as true section.
      Now I didn’t know that, and it will save me tons of work in making DWG files out of all the faces I generate.
      I haven’t seen anyone else mention this particular operation. So what are the other little known operations that you use that may be of some help to others.
      Ken
      • GaieusG
        I have to confess that I knew about this feature but only used once; when I tried it (as I have never needed it).
