    Your entire PC on a USB drive
    23 Posts 14 Posters 2.9k Views 14 Watching
      Jackson
      Congratulations Tomot, you've successfully taken the thread off-topic.
      Next time please start a new topic.
      Huh? Tomot explained (very clearly) the process of how he has managed to boot his entire PC from a 4Gb flash memory- how on earth is that off-topic?
      Jackson
        cdubea
        @marne said:
        I tried it, including SU. Very nice intention behind this program. Easy to setup and works like a charm.
        But as I tried to use it on a PC where I can't logon with administrative permissions it didn't work.
        I'm teaching SU on a college and wanted to show the students how my personal SU with all the plugins looks and works like (esp. the paid scripts) and it failed. Too bad.
        Beside I was missing an easy-to-use-encryption. By placing all my valuable πŸ˜„ scripts on a usb pen i may loose, anyone who finds it could browse through the (program files) folders (i think i was reading about improvements on this in the newest version...).
        For everyone having access to several pcs with admin permissions i would recommend it. Its a nice, "cheap" and better working alternative to thinstall πŸ˜›
        -just my opinion
        SketchUp can actually be run from a USB drive IF the host computer has dotnet framework installed.
        See my discussion at
        301 Moved Permanently
        (www.sketchucation.com)
        I use it pretty much every day at work on a machine I do not have admin privileges on.
        chris
          cdubea
          Windows XP only, but this little application (there is a free version) seems to be able to run applications portably even if they're not made as a portable application.
          http://www.mojopac.com/index.html
          This might be true, but there is a MAJOR gotcha. You have to have administrative privileges on the host machine.
          302 Moved Temporarily
          (system.netsuite.com)
          Kinda defeats the purpose.
          Something called MojoPac Usher can be installed on the host machine, but you have to have administrative privileges on the host machine to do so.
          Too bad, this could have been very useful!
          chris
          • 2 / 2
