    WxWindows for SketchUp Dialogs
    45 Posts 17 Posters 9.0k Views 17 Watching
      Jim
      Sang Ahn has posted this on the official GSU blog:
      wxSU is a plugin for Google SketchUp 6 that extends the SketchUp API with the capabilities of wxRuby. wxSU bundles wxRuby to provide a cross-platform, pure Ruby solution for implementing GUI dialogs in your SketchUp plugins.
      How cool is that?
        CPhillips
        Interesting. I am going to poke at it and see if it is any good.
        I wish this had come out before I learned (much more than I wanted) about JavaScript, HTML and all the weird idiosyncrasies of IE vs Safari.
          Matt666
          Cool !
          Frenglish at its best !
          My scripts
            Jim
            Me too. If this and WebDialogs had been released on the same day, I would have tried this first.
            It is cross-platform, by the way. For anyone trying to use WebDialogs, that's a huge advantage right now. Let us know how your experiments go.
              PeterCharles
              It's the end of the week and my eye's are growing dim....
              Where's the link to wxSU???
                alz
                @#*$! drool ...this is very cool...!
                  cdubea
                  wxSU
                  Download wxSU for free. wxSU is a plugin for Google SketchUp that extends the SketchUp API with the capabilities of wxRuby. wxSU bundles wxRuby to provide a cross-platform, pure Ruby solution for implementing GUI dialogs in your SketchUp plugins.
                  SourceForge (sourceforge.net)
                  chris
                    tomasz
                    It is an excellent idea. I have installed beta 0.10.
                    The 'controls', probably the most important example, doesn't work for me under WinXP.
                    It displays just a window with File, Tooltips and Panel menus, but not controls visible on wxRuby webpage.
                    As far as I understand this is rather an alpha? Isn't it?
                    Tomasz
                      Jim
                      The controls example does work for me under XP. But it also does crash frequently.
                      The author has it listed as a Beta status, but the version is 0.1.0 indicating a very early release.
                        david.
                        It's too bad that the SketchUp team didn't follow through on the UI support within the Ruby API. It's not bad, but it's could be a heck of a lot better.
                        I'm a bit concerned about wxSU because it seems just another potentially poorly supported or unsupported package. At least Javascript and HTML have well known, supported standards. They won't go away anytime soon.
                        • scottliningerS Offline
                          scottlininger
                          This is a good point. On one hand, you could argue that WebDialogs are the answer to complex UI inside SU, but in practice I think it's hard to find developers who are experts at ruby AND html AND javascript, which is largely what's needed to create solid UI inside a webdialog.
                          If people have seen any UI APIs that are worth looking at as a potential model for how we could extend Ruby UI support, please let me know.
                          • Scott Lininger
                            SketchUp Software Engineer
                            Have you visited the Ruby API Docs?
                            tomot
                            I think you guys started by using a hammer when you could have developed a scalpel. Archicad for example has a standardized built-in GUI, It does not need to be created each time someone wants to develop GDL scripts, to interact with the main program. Neither do I have to quit the main program just to restart the script to see if it works. I can run any script and see the results in its own window in 3d, and the error checking routine will point to any error in the script. In addition GDL is written in Basic, while not as code-dejour as Ruby its robust enough to develop complex 3d objects for ArchiCad.
                            Now that your down the road with the hammer your finding its to clumsy, so you try to fix it with adding more and more STUFF. Which means you will alienate guys like me, which are already less that .1% of SU users, that are already struggling with Ruby, and really don't care to learn 2 more languages just so I can make a simple script look good in a GUI.
                            Its to bad those learning programming today, are not taught the principle "less is more"
                            my plugins
                            tomot
                              PeterCharles
                              I may well get flamed but....
                              Multiple programming languages are the bain of my life! I'm a user and part time programmer so I want to be able to do something easily.
                              To illustrate, my problems started with web pages, where I needed an understanding of HTML. But some things HTML couldn't do so then I needed an understanding of JavaScript. But some code I didn't want exposed so I needed an understanding of Perl for CGI scripting. Then PHP became available so I needed an understanding of that (although I could drop Perl).
                              I had a CAD program with a straightforward macro programming language. But it had no GUI, but you could use VB to create one and interact with the program and macro so there was another program.
                              SketchUp came and I needed to have an understanding of Ruby.
                              I needed to automate Word, whose macro language was VBA. Still having now used VB I had a head start.
                              The main CAD software where I work is ACAD and Inventor, those macro languages are VBA. Oh, that's handy, worked with that before.
                              Finally, I had to create an on-line configurator for some machine selection as a Java Applet, so now I needed to have an understanding of Java.
                              MY BRAIN HURTS DOCTOR!!!!!! πŸ‘Š
                                david.
                                Nice point Peter, I feel your pain. I've gone through many languages, too. I like Ruby, but I already knew Perl, among others. And, this next point is not unique to Ruby, but it has had a number of recent security flaws. How do the fixes get patched into the SketchUp Ruby API? Seems like they will only come when a new version of SketchUp is released. Personally, I don't think this is good practice. But, the genie is out of the bottle, now.
                                I think people are trying to build a better mouse trap. And, programming languages are like "opinions"... everyone seems to have one.
                                • chrisglasierC Offline
                                  chrisglasier
                                  I don't know whether you have looked at this topic http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=12770. I am not expert at html and javascript, and the only ruby coding I have learnt from SFC experts like Jim and you (both web dialog video and blog). But I have learnt enough to design namesets to connect up quite different disciplines in a single endeavour ( e.g. the completion of a building project), with Sketchup components a key element.
                                  One member, Andrew Dwight (aadBuild), advised me in a PM that however good the concept, people still needed to see the detail of what it can do; I have been working on more video clips and commentary for that and hope to add a new post to the nameset intro videos topic this weekend.
                                  I hope you find this interesting.
                                  New post done - please use link in original post.
                                    tomot
                                    I can see this thread is about to die!
                                    If anyone would like another example, of how other 3d software programs
                                    have integrated languages into their main program, have a look at Modo.
                                    http://www.luxology.com/whatismodo/
                                    with special reference to
                                    http://www.vertexmonkey.com/scripts_modeling_create.php
                                    Here is a community which provides scripts written in Perl and Python
                                    which integrate seamlessly into Modo. Modo provides the Dialog interface.
                                    And while I see some forum members going GAGA over a commercial Profiler for SU.
                                    Its no big deal for Modo, someone has provided one since the release of Modo 201.
                                    Modo 201 come out about 2 years ago.
                                    my plugins
                                    tomot
                                      tomot
                                      Then why are you 'going GAGA' over Modo?
                                      I'm not going "GAGA over ArchiCad nor Modo", I'm simply mentioning these programs have had more success in how to integrate addon language components into their main program. Its my hope that SU will improve, and perhaps someone on their staff will look at those examples. ....That's ALL!
                                      I'm quite sure anyone that has ever written a Ruby program, would love to see a standardized Ruby GUI interface, becoming part of the next major release of SU.
                                      my plugins
                                      tomot
                                        tomasz
                                        Jim, you probably have Ruby installed, have you? I don't have. Will see if it helps.
                                        I hope this solution will be developed, as I hate playing with HTML and JavaS (I have already tied and have some 'success'). I would love to use Wx without bugsplats.
                                        Tomasz
                                          peter3443
                                          I've just posted version 0.2 of the wxSU plugin.
                                          You can download it here: http://wxsu.sourceforge.net/
                                          The new release fixes several bugs, updates to wxRuby 1.9.9, and has a few other improvements.
                                            Jim
                                            Welcome to the forums Peter; thanks for the update.
                                            • 1 / 3
