    Assign continuous UV coordinates to all selected faces?
    4 Posts 2 Posters 613 Views 2 Watching
    • N
      numerobis
      would it be possible to write a ruby which lets you pick up the UV coordinates from one defined face and assign it to all selected neighbouring faces at once instead of one by one - as you have to do if you want to produce a continuous texture on a curved surface in sketchup. would be a great time saver...
      • plot-parisP
        plot-paris
        I am not sure, what you mean. but wouldn't it do the trick, if you right-click the one face, select texture position and then "projected" now you use the colour picker (paint bucket + Alt key) to sample this texture , then select the whole terrain and colour it with this projected texture...
        • N
          numerobis
          Works! THANKS!
          I thought using "projected" would project the texture from one direction on all faces but the normal will be rotated... very cool! πŸ’š
          • plot-parisP
            plot-paris
            you are welcome, numerobis. yes indeed. the "projected" function is the only way to get organic models textured half decently.
            there is a ruby for spherical/cylindrical mapping. but it doesn't always work for me.
            my hopes lie with SketchUp7 and that they took in some of the suggestions that were made here in the forum (like a multipin-mapping system)
