    Vue render
    24 Posts 15 Posters 3.9k Views 15 Watching
    • daleD
      dale
      Thanks solo
      I use Cheetah 3d (mac user) for good 3d exports as well. Is the rendering process more "Podium" or "Kerkythea" like in complexity?
      • soloS
        dale,
        Niether actually, maybe closer to KT as far as complexity but different as the functions are node based (I think Lightwave has nodes too) and that takes some learning, the terminology is also a little different from most render apps.
        • C
          cadmunkey
          Fantastic updated image solo πŸ‘
          • EarthMoverE
            EarthMover
            Pete,
            I'm using DE 5.04 and tried your method of converting a .skp to .3ds. When I import into Vue, I get an error stating that the .3ds format is obsolete and that the materials may not be correctly converted. When I choose to import anyway, I indeed get some weird UV screw up that jumbles up my textures. Any clue why this is? Would an upgrade to 5.5 solve this issue? Also, is the .3ds convert/import preferable in your opinion to the .obj export from sketchup that Chipp Walters recommends? I'm excited for your Sketchup to Vue tutorial, as I think Vue fits my line of work (landscape designer) better than any other renderer out there.
            Content Creator at Skapeup
            • 2 / 2
