    [QUE] Why doesn't this draw the polyline?
    4 Posts 3 Posters 550 Views 3 Watching
    • H Offline
      herodes
      I found this example in the Wiki Api documentation pages.
      Bitly | Page Not Found | 404
      (bit.ly)
      model = Sketchup.active_model
      view = model.active_view
      point12 = Geom;;Point3d.new 0,0,0
      point13 = Geom;;Point3d.new 10,10,10
      point14 = Geom;;Point3d.new 20,20,20
      point15 = Geom;;Point3d.new 30,30,30
      status = view.draw_polyline point12, point13, point14, point15
      as it seems the polyline instructed isn't getting drawn.
      Is there something I am missing? Anything to watch out for?
      %(#BFBFBF)[http://arhitektonas.blogspot.com
      I know me,... I am that guy...
      • Didier BurD Offline
        Didier Bur
        Lot of ruby examples are wrong in the docs...
        I guess that a polyline must have coplanar points, and these aren't ?
        DB
        • H Offline
          herodes
          Hi Didier,
          # coplanar since z =0 on all these points...
          point12 = Geom;;Point3d.new 0,0,0 # z = 0
          point13 = Geom;;Point3d.new 10,10,0 # z = 0
          point14 = Geom;;Point3d.new 10,20,0 # z = 0
          point15 = Geom;;Point3d.new 10,30,0 # z = 0
          I tried this and it stil doesn't work, I also gave inputting an array for argument to the draw_polyline and it gives a Sketchup::View,..
          ... any other ideas ?
          • fredo6F Offline
            [EDIT] after some quick test
            view.draw_polyline works fine, but are you sure you execute your code within the drawmethod of a Tool (this is the only place where view.draw methods can work)?
            Otherwise, if you want to draw a polyline, you could also use view.draw GL_LINESTRIP, pt1, pt2, ...
            If you want to draw segments with each pair of points, use view_draw_lineor view.draw_lines. Very handy to draw in one shot a complex shape that you pre-calculated.
