    Is there a free plugin like smustards subdivide and smooth?
    32 Posts 9 Posters 4.7k Views 9 Watching
      @ Tekkybot: what you get now is a group which you cannot subdivide further UNLESS you explode it.
      @ Pilou: since the pro and free versions are practically the same now, I see no reason why it wouldn;t work in the free version.
      • Chris FullmerC Offline
        Does SU Free support encrypted Rubies? I think it didn't used to. So that was how sometimes SU free would not support a ruby that Pro did. I don't remember if the free version switched to now work with encrypted rubies.
          In the office I use the free version and have never had any problems with rubies since v6. In v5 the two versions were indeed different.
          • StinkieS Offline
            Stinkie
            The Maxwell plugin won't work with the free version - so there must be a difference.
              Well, it probably utilizes one of the exporters only the pro version has.
              But again, mine is just an opinion...😄
                den
                @tekkybot said:
                @remus said:
                Once youve put the files in your plugins folder, you just select the geometry you want to subd and smooth then go tools->catmull clark subdivision.
                what i did is, 1 put the plugins in my plugins folder, 2 create a box, and pull it up into a 3d cube, 3 select all, then go to tools, and catmull clark, when i do this, these three little dots appear, very small dots, but nothing else happens?
                yeah this happened to me but what i did was select the box and erase and found the subdivision was inside the box!! i guess the three dots were the points of the subdivision poking thru.
                hope this helps.
                  matteo
                  honestly, I like all the features of the subdivision and smooth ruby, except the fact that it multiplies the poly count by exponential factor.
                  Apart some easy models, this kills sketchup.
                  I prefer to create a simple shape in sketchup and edit it further with Wings 3D. It's more than a plugin, it's a real subdivision modeler, with a lot of features and handles very well hi-poly objects. It has a decent uv-mapping tool too, to edit your textures.
                  After you've finished with it, you can always re-export your model to sketchup and render it with your favourite style, or render it with almost any renderer you want.
                  If you want to give it a try, here the link: http://www.wings3d.com/
                  /matteo
                  hire me: http://www.nonsolo3d.it/ !
                    In what format reimport your file from Wings3D ❓
                    Seems only 3DS can be possible 😒
                    But this format has some limitation (65 535 limits by facts polys...)
                      matteo
                      yes, 3ds format keeps well the textures too. Sometimes I succeeded to import an obj file, with the apposite ruby: it allows you to keep square coplanar faces, instead triangular ones. But it is still a buggy plugin.
                      For me 65 535 polys are more than enough to be handled by sketchup. I prefer not to exceed 1/4 of that limit to keep my workflow fluid and smooth, and even keep working on my laptop. Or share it with other people.
                      But this depends on the goal you pursue. I prefer to have a small load and run faster and believe that a good texture + 4 poly is better than a bad texture + 100 polys: there is a sort of beauty in keeping the poly count as low as you can.
                      /matteo
                        Of course : small is beautiful ☀
                        • 2 / 2
