    Green Toaster's Car Sketches
    745 Posts 45 Posters 94.7k Views 45 Watching
      GreenToaster
      . . . boring but very fast model . . .
      If you really want something you won't ever stop pursuing it.
        GreenToaster
        . . . WIP . . .
          GreenToaster
          . . . another generic, aero-car . . . :zzzzzzz: . . .
          • RayOchoaR Offline
            RayOchoa
            What is that front of car or something on the WIP?
            looks cool so far. by da way check out ma latest design tell me what you tink. http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=9891&st=0&sk=t&sd=a&start=45
            its the blue one all the way down
            CaR DeSiGnS bY mE
            http://ray-ochoa.com
              GreenToaster
              Yes - I made an edge that flowed from the middle front then traveled to the side behind the wheel, then I created a corner profile, then used "Follow Me" tool - something different from what I usually do. I'm always trying to do stuff a new way, a different way, in hopes it will help - sometimes I learn something useful, sometimes I don't - I always enjoy trying new ways of creating and editing geometry.
              Very nice - as usual. You may want to shorten the size of the door - is it too long in the front part of the door? Looks great - keep going.
              This image below is another example where I was just trying something different - just for fun. It's really obvious when I create an especially hideous design because no matter what angle you're looking at the model, it still looks really awful. 🀒
              So, no big deal, failure is certainly part of the process, eh? Toss it, do another one.
              Happy Sketching,
              Brad
              πŸ˜„
                GreenToaster
                . . . another quicky . . . yes, I was indeed watching the races this weekend in Utah . . . needs a lot of work with all the sloppy details . . . on to the next one . . .
                Happy Sketching,
                Brad
                πŸ˜„
                • RayOchoaR Offline
                  RayOchoa
                  really good racing car right ther. i would finish and render that one if i was you
                  CaR DeSiGnS bY mE
                    GreenToaster
                    Thank you! I might finish this one and render it but I doubt it because that would take time away from the other (important) parts of my life.
                    I was doing very good to have barely enough time to squeeze this one in - it was a very busy weekend and this upcoming week doesn't look any better - no more time for fun . . . er, I mean no time for developing my SketchUp skills.
                    Happy Sketching,
                    Brad
                      GreenToaster
                      . . . I need to redo the fender well areas because I don't like the way these turned out . . . this won't be too difficult to change . . . it's always easy to fix something when you're using SketchUp . . . πŸ˜„ . . .
                      • ely862meE Offline
                        ely862me
                        geting closer...well done!!
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                          GreenToaster
                          Thank you.
                          Here's an image showing a technique I finally figured out which has helped me define shapes rather quickly and with lots of control. The red stripe coming around the "corner" of the front end of the car was created using two planes to define a 3D path, then I used a 3 sided section (5 actually with 2 later removed) with the Follow Me tool. The stripe down the center of the car has nothing to do with this technique but I thought it might look good (ha). As always, the car is symmetrical left to right, so only half is actually shaped.
                          It's a nice technique to have available when you need it - as long as it's not "overdone." I'll post a tutorial if anyone's interested in seeing how I do this but I'm sure it can be done better, quicker, more artistic by others.
                          Happy Sketching,
                          Brad
                          πŸ˜„
                          • RayOchoaR Offline
                            RayOchoa
                            i would like to see it πŸ˜„
                            CaR DeSiGnS bY mE
                              GreenToaster
                              . . . okay, I did a super-quick video tutorial but I can't upload it from work 😞 . . . I'll post it tonight.
                              Happy Sketching,
                              Brad
                              πŸ˜„
                                remus
                                Cheers brad, your tehnique sounds very interesting.
                                The latest few cars are looking pretty cool as well, the proportions are spot on.
                                  GreenToaster
                                  I think this is a link to the video I created this morning and posted this evening - again, sorry for the lousy quality but I think you can get the idea - nothing earth shattering new or difficult:
                                  301 Moved Permanently
                                  (www.sketchucation.com)
                                  Thanks and happy Sketching,
                                  Brad
                                  πŸ˜„
                                    GreenToaster
                                    . . . the proportions are spot on.
                                    Thanks - I'm not very good at this - very much hit & miss, more miss than hit. πŸ˜‰
                                    Here's the finished concept model using the geometry from the video tutorial.
                                    Happy Sketching,
                                    Brad
                                    πŸ˜„
                                      GreenToaster
                                      . . . more sketching . . .
                                        You have never try nurbs modeling?
                                        Because you have this directly in the prog β˜€ By Marcorhino (here Moment of Inspiration who has export SKP)
                                        Remark the refinement and softness of the drawing's lines themselve! 😲
                                          remus
                                          Your starting to sound like an moi sales person pilou πŸ˜›
                                            Sorry Remus tell me if I overpass the limit submerged by my enthusiam I will stop immediately πŸ˜„
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 37
                                            • 38
                                            • 31 / 38
