    Green Toaster's Car Sketches
    745 Posts 45 Posters 171.1k Views 45 Watching
      GreenToaster
      . . . blah, blah, blah . . .
      If you really want something you won't ever stop pursuing it.
      • CraigDC Offline
        CraigD
        That's really cool Toaster! Your work is getting more and more sophisticated! πŸ˜„
        Cheers,
         - CraigD
        Google SketchUp
          GreenToaster
          Thanks Craig. I enjoy using SketchUp much more when I'm not pressed for time - like, when I actually set aside a large segment of time like maybe an hour or so. It's amazing what a difference can occur when you have a bit more time to devote to something. My dream would be to do this for 8 or 10 hours a day . . . okay, maybe 10 or 12 hours a day . . . 😍
            GreenToaster
            Whoa!
            That's all I can say about this one . . . got a little carried away with the nose, I guess.
              GreenToaster
              . . . a few minor adjustments . . . maybe I could be a plastic surgeon someday . . . 🀣 . . .
                GreenToaster
                . . . boring but very fast model . . .
                  GreenToaster
                  . . . WIP . . .
                    GreenToaster
                    . . . another generic, aero-car . . . :zzzzzzz: . . .
                    • RayOchoaR Offline
                      RayOchoa
                      What is that front of car or something on the WIP?
                      looks cool so far. by da way check out ma latest design tell me what you tink. http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=9891&st=0&sk=t&sd=a&start=45
                      its the blue one all the way down
                      CaR DeSiGnS bY mE
                      http://ray-ochoa.com
                        GreenToaster
                        Yes - I made an edge that flowed from the middle front then traveled to the side behind the wheel, then I created a corner profile, then used "Follow Me" tool - something different from what I usually do. I'm always trying to do stuff a new way, a different way, in hopes it will help - sometimes I learn something useful, sometimes I don't - I always enjoy trying new ways of creating and editing geometry.
                        Very nice - as usual. You may want to shorten the size of the door - is it too long in the front part of the door? Looks great - keep going.
                        This image below is another example where I was just trying something different - just for fun. It's really obvious when I create an especially hideous design because no matter what angle you're looking at the model, it still looks really awful. 🀒
                        So, no big deal, failure is certainly part of the process, eh? Toss it, do another one.
                        Happy Sketching,
                        Brad
                        πŸ˜„
                          GreenToaster
                          . . . another quicky . . . yes, I was indeed watching the races this weekend in Utah . . . needs a lot of work with all the sloppy details . . . on to the next one . . .
                          Happy Sketching,
                          Brad
                          πŸ˜„
                          • RayOchoaR Offline
                            RayOchoa
                            really good racing car right ther. i would finish and render that one if i was you
                            CaR DeSiGnS bY mE
                              GreenToaster
                              Thank you! I might finish this one and render it but I doubt it because that would take time away from the other (important) parts of my life.
                              I was doing very good to have barely enough time to squeeze this one in - it was a very busy weekend and this upcoming week doesn't look any better - no more time for fun . . . er, I mean no time for developing my SketchUp skills.
                              Happy Sketching,
                              Brad
                                GreenToaster
                                . . . I need to redo the fender well areas because I don't like the way these turned out . . . this won't be too difficult to change . . . it's always easy to fix something when you're using SketchUp . . . πŸ˜„ . . .
                                • ely862meE Offline
                                  ely862me
                                  geting closer...well done!!
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                    GreenToaster
                                    Thank you.
                                    Here's an image showing a technique I finally figured out which has helped me define shapes rather quickly and with lots of control. The red stripe coming around the "corner" of the front end of the car was created using two planes to define a 3D path, then I used a 3 sided section (5 actually with 2 later removed) with the Follow Me tool. The stripe down the center of the car has nothing to do with this technique but I thought it might look good (ha). As always, the car is symmetrical left to right, so only half is actually shaped.
                                    It's a nice technique to have available when you need it - as long as it's not "overdone." I'll post a tutorial if anyone's interested in seeing how I do this but I'm sure it can be done better, quicker, more artistic by others.
                                    Happy Sketching,
                                    Brad
                                    πŸ˜„
                                    • RayOchoaR Offline
                                      RayOchoa
                                      i would like to see it πŸ˜„
                                      CaR DeSiGnS bY mE
                                        GreenToaster
                                        . . . okay, I did a super-quick video tutorial but I can't upload it from work 😞 . . . I'll post it tonight.
                                        Happy Sketching,
                                        Brad
                                        πŸ˜„
                                          remus
                                          Cheers brad, your tehnique sounds very interesting.
                                          The latest few cars are looking pretty cool as well, the proportions are spot on.
                                            GreenToaster
                                            I think this is a link to the video I created this morning and posted this evening - again, sorry for the lousy quality but I think you can get the idea - nothing earth shattering new or difficult:
                                            301 Moved Permanently
                                            (www.sketchucation.com)
                                            Thanks and happy Sketching,
                                            Brad
                                            πŸ˜„
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 37
                                            • 38
                                            • 30 / 38
