    Exchanging color to texture?
    18 Posts 4 Posters 2.5k Views 4 Watching
    • PixeroP
      Pixero
      Thanks, I just tested the code and there seem to be something wrong with the file that it creates. I cant open it in any image editor I have including Photoshop. Says cant parse the file. Any ideas?
      • tbdT
        tbd
        hmm, I tested in SU, PS and TotalCmd Imagine viewer plugin and it works ok
        http://plugins.ro
          Masta Squidge
          Couldn't you just go through the colors after you placed them all and then manually edit each one to the texture you want? this would automatically replace every color in the model with the texture you change it to. I do it on most of my models. Granted my models stink half the time but hey, it works. Like say, you want Grey (or is it Gray ๐Ÿ˜›) to be a wall texture on a bunch of different walls, but not all of them. Just paint the grey color on the walls then edit that material later. It also doesnt mess up the default colors of SU and on a new file they load default. Im guessing you use colors as placeholders (thats what I do) because textures slow down SU?
          Or am I missing something totally and have no idea what you are talking about ๐Ÿ˜ฎ ?
          • PixeroP
            Pixero
            I'm currently evaluating a possible future workflow for real time presentations. (Modelling in SketchUp, lightmapping in another program and finally viewing in a third.)
            Doing it once or twice is one thing. Doing it a lot of times is another. Therefor I'm looking into a automated way of doing it.
            TBD, I have to look into this further.
            • PixeroP
              Pixero
              I still havent got this to work.
              TBD, I've tried your code on several PC's and it creates a png but I still canยดt open it with either photoshop or sketchup.
              Any ideas? Is there another way?
              Edit: I opened the created png in a texteditor and it looks like this:
              โ€ฐPNG
              SUB
              NUL NUL NUL
              IHDR NUL NUL NUL EOT NUL NUL NUL EOT BS ETX NUL NUL NUL ลพ/nL NUL NUL NUL ACK PLTEรฟรฟ NUL NUL
              Another edit: I attach the png:
              • tbdT
                tbd
                can you open this png ? it was generated from the code posted above
                I can see it with TotalCmd image viewer, but Sketchup cannot use it ๐Ÿ˜ž
                def create_small_png(red,green,blue, filename)
                  small_png = %{iVBORw0KGgoAAAANSUhEUgAAAAEAAAABCAMAAAAoyzS7AAAAA1BMVEX/AAAZ4gk3AAAACklEQVQYV2NgAAAAAgABo9o9lAAAAABJRU5ErkJggg==}.unpack("m").to_s
                  color_pos = 41
                  small_png[color_pos]   = red.chr
                  small_png[color_pos+1] = green.chr
                  small_png[color_pos+2] = blue.chr
                  File.open(filename,"wb") {|x| x.write small_png}
                create_small_png(255,0,0,"d;/test.png")
                test.zip
                http://plugins.ro
                • PixeroP
                  Pixero
                  I can open your image in Photoshop but not in SketchUp. So no good. ๐Ÿ˜ž
                  Is there a way of having the png as rgb instead of as indexed pallete png?
                  Is that why its not working in SketchUp?
                  • tbdT
                    tbd
                    have you tried latest code (forgot to modify the text on the message as well) - for me it works in Sketchup as well.
                    weird as the material shows as color based, not as texture - but it works.
                    I used a an indexed because it is easier to change colors and have a base png to start of. using a rgb is much more harder and needs more code for it ๐Ÿ˜‰
                    http://plugins.ro
                    • PixeroP
                      Pixero
                      Still doesnt work in Sketchup.
                      • tbdT
                        tbd
                        here it works ๐Ÿ˜„ ... it creates an 82 bytes png, which I can drag and drop
                        in SU (using ALT to have it fill the face underneath the bucket)
                        as I said before - works only in Shaded mode, in Shaded with Textures I get a white face ๐Ÿ˜ฒ
                        http://plugins.ro
                        • PixeroP
                          Pixero
                          Tried again and on a different PC still not working in SU.
                          How would the RGB way look?
                          If I open the png in PS and change it to RGB it works the way you say in SU but not in textured mode.
                          What if the image was bigger say 64x64 pixels?
                          • tbdT
                            tbd
                            a lot more complicated ๐Ÿ˜„ ... you can try to save as png, find the offset inside the file where color is store, pack("m")
                            donno. i used 1x1 pixel to keep the file to minimum
                            make a hash of the file that you create via the script to see if it is written properly
                            http://plugins.ro
