    Rogue Renders!
    44 Posts 12 Posters 7.5k Views 12 Watching
    • FrederikF
      Frederik
      @gaieus said:
      (correct me, Kim, if I'm mistaken - I haven't touched Kerky for months 😳 ).
      You're absolutely right, Csaba..! 👍
      Cheers
      Kim Frederik
      • Roguer1R
        Roguer1
        Thanks all for the advice. I am still mucking arround in Kerkythea and all the work I have done can be seen above and on my website. From what you can see its not a lot but it can only get better
        Find all my models on the 3D Warehouse
          Jackson
          Wow, nice models! What sort of poly count are you achieving with these?
          Jackson
          • Roguer1R
            Roguer1
            Thanks, I am currently making models with up to about 45,000 poly's. Most of the models above range from 15,000 to 30,000 but one or two, such as the M14 and Falcon Coupe, sit at about 45-55,000
              Jackson
              Wow, most of the low poly cars I use are around 5000 faces, but then they don't look as good as yours and the interiors are very minimal.
              Jackson
              • Roguer1R
                Roguer1
                I have noticed when I started modeling my models were at about 2,000 to 7,000 but I have begun to add more and more detail resulting in much more poly's. I also model my own wheels, I use a circle with 100 sides so they, themselves, can reach about 5,000. I also model most of the running gear, engine and under body of the car too. Here are some quick images of these things:
                  Jackson
                  Ahhh, it's the wheels that are the killers- are you sure those little radii on the rims are necessary- they seem a bit extraneous unless you're doing extreme close-up renders. Not a criticism, I'm just a bit of a low-poly obsessive as I often have to put tons of trees, cars etc into large urban models, always looking for ways to keep my larger skp files workable. Beautiful models- are they worked up from elevations or just photographs?
                  Jackson
                  • Roguer1R
                    Roguer1
                    I am a bit of a detail freak too but I'm the other way with it. If I can add more detail to make it more realistic, I will. Wheels are often a focal point of a car, if they look like c#@p then most people won't look twice at it but if they are clean and attractive it makes the car stand out that much more.
                    Most of my models are built up from blueprints either done by me or from cars I really like. I have modeled one or two from just photos but I find it a lot more difficult. Although with many blueprints, they often are not in proportion and that can lead to a inaccurate model. I have also modeled a few from scratch, most of my older models are scratch built.
                    Here are a hand full of WIP's:
                      Jackson
                      Fantastic, thanks for the description and images. 👍
                      Jackson
                      • Roguer1R
                        Roguer1
                        No problem, any time.
                        Now that i mention it, I am offering SketchUp help on my website, kind of a Q and A. People just send me a SketchUp user query or a question relitive to SketchUp and I will respond with as much info as I can.
                        • RayOchoaR
                          RayOchoa
                          im using the same technique as you right now and im pretty happy with the results i get. and about unproportional blueprints its all the matter of the scale tool.
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • Roguer1R
                            Roguer1
                            I use the scale tool. I match up all points as much as possible but sometimes the bits inbetween are off by a bit and it can often make a model look a bit odd. Like with the falcon im building. The front and rear of the top and side view match perfectly but a few details in between dont.
                            • Roguer1R
                              Roguer1
                              I like this next car soo much, its the Ford Visos Concept:
                              • Roguer1R
                                Roguer1
                                And here is the Ford Falcon BA:
                                • FletchF
                                  Fletch
                                  great work!
                                  I highly recommend using Alex's car rendering studio (or cheat and use his HDR to light the scene) with the PM+FG High+AA preset - or better- MLT... you'll love the results.
                                  Jon created a studio that incorporate Alex's HDR, see this thread. (But Alex states he doesn't believe HDR is a great way to light car renderings - an actual light studio you can tweak for each car is better - in his opinion)
                                  to load an HDR in the 'sky'
                                  simply go to sun & sky wizard, skip sun settings>go to sky tab, choose 'spherical sky' and click the black box to load the hdr. then find/load the Alex studio hdr.
                                  or you can also install the HDR probe library from the kerkythea.net downloads section.
                                  then just insert>globals>pick your HDR, and it will set up the scene lighting for you.
                                  be sure to let the HDR do the lighting and turn off any lights you've inserted.
                                  then render.
                                  be sure, also, to try out the metals Patrick posted in the downloads section.
                                  lastly, Alex, whom I would consider one of the Car-rendering-gurus of KT only uses MLT render preset or MLT/BiPT... they do take about 12hrs to render that way, but look fantastic... and it's very simple to do. He's got a great thread about his car rendering studio technique here.
                                  keep up the great work!
                                  also, try some photography studio HDRs by Rayman.
                                  Fletch
                                  • Roguer1R
                                    Roguer1
                                    @fletch said:
                                    great work!...
                                    ...great work!
                                    Thanks I will some time
                                      dacad
                                      Hi Rogue
                                      I really think that you're renders have potencial (especially the first ones). You should try to get away from the realist renders and start to mix with the sketchup export of lines and then put everything together in photoshop (or GIMP or Net. paint that are free) using multiply or overlay. The results would be a more artistic renders (wich honestly i prefer and can reveal the sensebility of a person to plastic issues). After getting used to this method start playing with styles of lines of sketchup and in a more advance stage with the filters for colour treatment in photoshop.
                                      Try this little experiment and you won't regret it
                                      keep them coming.
                                      Hugsss
                                      • Roguer1R
                                        Roguer1
                                        Thanks for the comments and suggestions.
                                        I have Photoshop CS2 but I’m not that good in it, to be honest, I’m shet!
                                        I have just got my hands on Fryrender and will be having a bit of fun with it over the next few days.
                                        Lets see how it goes!.............Any tips?
                                        • K
                                          KDSDESIGN
                                          Nice. wait. 2 render programs?
                                          Regards,
                                          █Kevin█
                                          (about 20% done)
                                          • Roguer1R
                                            Roguer1
                                            Well, after a little play around with Fryrender I have finished my first test renders.
                                            Each render took 3 hours
                                            Its a little bit rough and not very high quality but it looks ok from a distance. I hope I can figure out how to use the program a little better.
                                            So, what do you think?
                                            • 2 / 3
