    My ruby's
    22 Posts 12 Posters 5.9k Views 12 Watching
      bellwells
      @pixero said:
      Just a thought... are you extruding in a direction that is possible?
      (I mean not in 90 degrees from the surface normal.)
      And of cause you'll have to click ok.
      Other than that I dont know. Are you on Mac or Windows?
      And Coen, I want people to come to my site to download.
      Jan,
      Sorry it took me so long to acknowledge your reply. As is often the case, it was my fault-operator error.
      Thanks.
      Ron
      • PixeroP Offline
        Pixero
        Added small update to jsBackgroundColor.rb so you now can control ground color as well.
        No website is present on this hostname
        The website you are trying to reach could be suspended, deleted or DNS could be incorrect
        (www.pixero.com)
        • PixeroP Offline
          Pixero
          While working on another script I stumbled on this (camera.focal_length) in the docs.
          I haven't seen this before and since I repeatedly have had problems with using field of view I though I'd share it.
          Here is a small script called jsFocalLength that lets you set the cameras focal length in mm. You'll find it under Camera menu.
          (www.pixero.com)
          • tbdT Offline
            tbd
            is not the same as entering "35mm" in VCB while on Zoom tool ?
            http://plugins.ro
            • PixeroP Offline
              Pixero
              Ok, I never knew it was there. Anyway, if anyone wants it...
              • PixeroP Offline
                Pixero
                Added js Frame Step. A script for showing a specified frame of an animation.
                You need at least two scenes for it to work. Type in the frames per second you use (Typically: NTSC 30, PAL 25, Film 24) and then the frame you want to go to.
                Added js Camera Tool. A script for offseting camera rotation and translation numericly.
                (www.pixero.com)
                • PixeroP Offline
                  Pixero
                  Updated my jsMoveTool at a request. Now press ctrl (Apple key on Mac) to move 1/10 the entered value and Shift to move 10 * the entered value. (And press alt for moving in Z direction as before.)
                  Thanks to Rick W for fixing a bug.
                  Get it at my site http://www.pixero.com
                  Enjoy! πŸ˜„
                  • 2 Offline
                    2myChaGrin
                    Thanks so much for you work Jan. I use your scripts quite often and have never officially said thank you.
                    • Z Offline
                      zed252000
                      πŸ‘
                      this will be helpful.
                      thanks!
                      Whatever we IMAGINE....
                        brechtix
                        The new and improved jsmovetool is handy for adjusting dimensions as well.
                        Eagerly awaiting Layout 1.0 with ruby...
                        Brecht.
                          matt77
                          Hi Pixero,,
                          Many Thanks for the scripts, especially the JS frame step,
                          this isn't necessarily a request for you but I'm surprised this hasn't been discussed more.
                          Could this not be incorporated or adapted so that it could be used with some rendering software to produce animations. Unless i missed something I'd have thought this would have jumped on many others.
                          either way
                          many Thanks
                          Matt
                          • 2 / 2
