    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Wx::DateTime:Class
    8 Posts 3 Posters 685 Views 3 Watching
    • Al HartA Offline
      Al Hart
      I have a client who is getting this error:
      undefined method `now' for Wx::DateTime:Class
      for the statement DateTime.now
      When I type in an illegal function for DateTime (e.g. DateTime.xxx) I get this error
      Error: #<NoMethodError: (eval):196: undefined method `xxx' for DateTime:Class>
      With no mention of WX. I suspect the client may have another ruby script which is defining its own DateTime class.
      I see that the Wx::DateTime class does exist for ruby.
      Is anyone using it?
      Has anyone heard of it?
      Can anyone think of how I can force my .rb files to use the DateTime defined in SketchUp's date.rb?
      Google SketchUp 6\Tools\date.rb(1092):class DateTime < Date
      Al Hart
      IRender nXt from Render Plus
        todd burch
        SketchUp doesn't have a date.rb. Where did that come from?
        • Al HartA Offline
          Al Hart
          AHA - that's part of the mystery. We are installing date.rb from ruby 1.8.5 ourselves.
          (We install several base ruby things such as Win32API.so and date)
          Still - I would like to know which plugins are installing the Fx::DateTime.
          Al Hart
            todd burch
            I would encourage you to NOT use the /Tools folder. Using the /Tools folder will cause grief and heartache when your users go to upgrade from SUV6 to a subsequent version. I promise.
            Let Google have the /Tools folder and we can all play nicely in the /Plugins folder. Perhaps you could implement an /RP folder with all your stuff under /Plugins, to isolate potentially common names like 'date.rb' from conflicting with others.
            For your user's issue, I would suggest getting a list of all the loaded scripts and their classes and methods. Sounds like an obvious case of a method being overridden.
            I suspect if you create yourself a module and make your date.rb a mixin in it, you'll be fine.
            • Al HartA Offline
              Al Hart
              Thanks Todd,
              I'm also trying to get the user to type in:
              ::DateTime.now to see if that causes it to use DateTime rather than Fx::DateTime
              I'll try putting date.rb somewhere else and see if I can get it to work.
              Al Hart
                todd burch
                Just moving the file (date.rb) somewhere else won't fix anything.
                • Al HartA Offline
                  Al Hart
                  No, It will only help next time when I find it in Tools and think it is part of SketchUp rather than a file installed by Render Plus.
                  Al Hart
                  • H Offline
                    herodes
                    WX probably refers to the WxWidgets namespace. A GUI Toolkit like FoxGUI.
                    I can't really see anything. What type of computer is the client running on?
                    %(#BFBFBF)[http://arhitektonas.blogspot.com
                    I know me,... I am that guy...
