    [Ruby doc] .materialType method
    8 Posts 4 Posters 1.5k Views 4 Watching
      tomasz
      materialType
      The materialType method retrieves the type of the material.
      Syntax
      type = material.materialType
      Return Value
      type - the material type for the Material object
      The last line explains everything. πŸ˜†
      As far as I can tell:
      0 - just coloured material
      1 - textured
      2 - texured & coloured
      A strange thing - when I reset colour of the texture the Type stays 2!!
      I am intensively looking for a method that would tell me if a texture on a face is 'projected/photomacthed' or not. This one doesn't seem to do the job 😞
      I hope a Google friend will enlighten us or we can somehow figure it out together.
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        tomasz
        Any clue? I know there are a lot commercial exporters and SU2KT is a great rival πŸ˜„
        Tomasz
        • N Offline
          notareal
          ...'projected/photomacthed'
          Sorry cannot help with that. But it would be great if there is a way to find out it.
          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            todd burch
            I'm working on getting an answer for this.
            Todd
              todd burch
              I checked with Google. You are correct, these are the values:
              0 = solid
              1 = textured
              2 = colorized textured
              I've updated the doc: http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Material.html?hl=en#materialType
              Todd
              • F Offline
                Fletch
                Todd, I'm not quite clear, sorry 😳
                Correct me if I'm wrong, I read the post you linked at google groups, but it's apparent to me, (I'm no programmer) then that it's impossible with the methods provided in SU6 to check to see the difference if a material applied in the scene is a photomatched texture or just any old .jpg Texture.
                πŸ’­ If not, will there be a patch released to provide a method? Or at least can google team please confirm providing this method in SU7 ❓
                Fletch
                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                  todd burch
                  @fletch said:
                  ... it's apparent to me, (I'm no programmer) then that it's impossible with the methods provided in SU6 to check to see the difference if a material applied in the scene is a photomatched texture or just any old .jpg Texture.
                  And you would be correct. There is not Ruby support for Photomatch in V6. I can't speak for V7.
                    tomasz
                    It is sad. So maybe SU SDK could help, but it isn't within my abilities to play with it.
                    def SU2KT;;texture_distorted?(e,mat,mat_dir)
                    	distorted=false
                    	temp_tw=Sketchup.create_texture_writer
                    	model = Sketchup.active_model
                    	entities = model.active_entities
                    	model.start_operation "Group" #For Undo
                    	group=entities.add_group
                    	group.material = mat
                    	g_handle=temp_tw.load(group)
                    	temp_handle=temp_tw.load(e,mat_dir)
                    	entities.erase_entities group
                    	Sketchup.undo
                    	distorted=true if temp_handle!=g_handle
                    	temp_tw=nil
                    	return distorted
                    Here is what I am doing in SU2KT, but it is slow, memory consuming and dirty. 😞
                    Btw. Todd - have you noticed that .materialType doesn't change from 2 back to 1 if a material is not longer colorized. Am I correct?
                    Tomasz
