    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Hello! Love the board... care to critique a project?
    26 Posts 12 Posters 1.9k Views 12 Watching
      mirjman
      hey nice work! awesome environment feel... the only thing that strikes me is that there is a lot of black asphalt in the view. Some things you might try are just lightening it up color wise so it isn't such a contrast, tilting the view up so it doesn't take up so much of the frame, or just breaking it up with some landscaping/cars/or people even if that is not the actual design.
      great detailed look to it though, very convincing
      • O Offline
        outersketcher
        It looks GREAT to me. You've managed to divest the building of the "Sketchup look" quite nicely. Care to explain a little bit how you performed the render?
        David
        "I mostly enjoy not being dead.." -Grandpa
          spunky
          Thank you! I Am just starting a rendering firm... (is it a firm if it is just one person?) and wondered how far along I was... MOst of this is done in photoshop, the sketchup is the easiest part, the photoshop, that is the hard part... anyone use Podium and really like it?
            ridix
            Nice render. Two comments. Trees on the foreground really need to cast some kind of a shadow; looks pasted. And the curves seem little too high; its almost look like a wall. May be the edges are made too sharp. Is that a Mission Peak on the background?
            • Chris FullmerC Offline
              The fire hydrant:
              Use this to help make a better design. Don't remove the hydrant from the render just so it doesn't detract from the building. If it really detracts, then it should be re-designed to go somehwere else on the grounds. Or perhaps redesigning it to be toned down a little. Bit if it has to stay there and it has to be red, do not remove it from the rendering. That would be lieing.
              Intermountain health clinic? Isn't that on the wasatch front?
                spunky
                It is actually here in Sunny (and hot as hades) St. George...
                  Ahh, the background mountains weren't as red as I would expect for St. George. My parents live in Ivins. Quite nice out there, but it is a bit warm this time of the year (most times of the year really). Anyhow, really nice work spunky.
                    galbavy1
                    select the hydrant with the lasso in photoshop and image-adjustment-hue/saturation---desaturate it about 50%, that should help. Saturated colors often don't stand out that much in real life due to material properties like texture and the reflection of the immediate area on it.... I get away with setting the opacity back a bit to avoid putting shadows on photoshopped trees. The transparency "tricks" the mind to not pay as much attention to the plant material- thats the goal if you want to empahasize the architecture, not the landscape... looks really good though!
                      I think its valid to lighten the red hydrant up if it is brighter than it would be in real life. Great tip.
                      But why woud someone want to highlite the architecture and not the landscape?
                      Chris - Landscape Architect (student)
                        galbavy1
                        hey man, LA power all the way! (Im a UF grad and now work at a firm in Tampa) All Im saying is you can strengthen what it is that your trying to present but reducing everything else. When I do renderings for architects I try to make sure that the landscape doesn't detract from the building.... vise versa when I present a landscape plan. Of course in real life they should be designed equally together so they look great together. Have you had a chance to visit Peters' office right above you there? I got to see some of conceptual models for the trade center before they went public!
                          All right, as long as you're not the architect type who doesn't understand why we should even include plants in renderings ๐Ÿ˜„ Theres a lot of them around me where I am I think. I see lots of work that never includes a single photosynthesizing object.
                          • E Offline
                            evilelvis
                            That looks great!
                            Nice shadow work mate ๐Ÿ‘
                            http://www.coroflot.com/MDVee
                            • brodieB Offline
                              brodie
                              I don't think anyone's mentioned this so I will. You might relook at how the foreground trees meet the ground. It looks like they run right into the sidewalk area. Might look less pasted to have something at the base. A little mulch, some grass, rocks, something like that.
                              -Brodie
                                spunky
                                This has been great... I miss being in college and having peer reviews... (I was a photography major). Just after you leave that warm cocoon of creativity... you are just, without perspective on your own work, and you run the risk of thinking all your stuff is just great. So I love this! Thank you all!
                                  spunky
                                  And here are the results of all your help!!!!!
                                  THANK YOU!!!
                                  • DanielD Offline
                                    Daniel
                                    Looks great, but Eric is correct - trees wouldn't grow right out of the pavement like that.
                                    My avatar is an anachronism.
                                    • brodieB Offline
                                      brodie
                                      I think I misread that from a distance. The second perspective makes it more clear that what I thought was pavement is actually a large rockbed in between the viewer and the building (right?). Nevertheless, it still seems an odd condition for trees to be growing from.
                                      I feel like I'm playing one of those picture games in the dentist's office where it says there are 6 differences between these two photos...
                                      Can you tell us exactly what you've changed from the first render to the last? I noticed that you've zoomed in which was a good call. And I think the whole thing seems a bit brighter too which is an improvement. What else is in there that I'm missing?
                                      -Brodie
                                        spunky
                                        I know... I thought so too. Here is a picture of the actual clinic. I love St. George, but there landscaping is sparse and at times rather boring. I put shadows on all plants and trees, sharpened and blurred a bit here and there and then lightened it up a bit.
                                          Yup, welcome to the southern Utah desert. Trees do in fact grow right out of rock beds there. And that is a bright red firehydrant in real life too ๐Ÿ˜„
                                          • brodieB Offline
                                            brodie
                                            Hrm...not bad but the sky could use some clouds, take out the manhole cover right in the foreground, and that guy getting out of the jeep is totally unrealisic. Not bad materials though aside from the asphalt.
                                            ๐Ÿ˜ฎ oh wait, it's real. ๐Ÿคฃ
                                            -Brodie
