    Problem with object sinking
    17 Posts 3 Posters 2.7k Views 3 Watching
      Dik Harrison
      Why does the Traveler in the attached file "sink" into the rail when SP is run? And why does it not stay trapped by the ridge on top of the rail? I thought I was getting along fairly well with SP, but this has me stumped.
      PBB-2550_SRK.skp
      Have fun...
      Dik πŸ˜•
      Have fun...
      Dik
        GreyHead
        I think that it may be because the slider that controls the traveller motion isn't exactly parallel to the rail. The guide-line in the picture is taken from the rail edge to the corner of the far end of the slider.
        Bob
          Dik Harrison
          Thanks Bob, I see if I can straighten that out...
          I set the slider parallel to the rail and the traveler now functions better πŸ˜„ , thanks. However, the traveler still sinks into the rail 😞 ...
          Revised file.
          Have fun...
          Dik
            Dik Harrison
            Actually, when I first started this drawing, the rail, when it was lowered completely, was sinking into the top of the table at the far end from the servo, but I added a clear SP box coplanar with the unit on that edge of the table, and the problem went away. Just tried that with the rail, no joy...
            Have fun...
            Dik
              CPhillips
              I dont really see the problem. But it could be because of the position of the joint. Objects can sag if they move too far from the center of the joint. Maybe move the slider to the middle of the rail?
                Dik Harrison
                This pic is without SP running, the traveler is resting on the top surface of the rail as is desired.
                This is how it should be.
                In this pic, SP is running, and the traveler is sitting about 1/4" below the top surface of the rail.
                This is how it is.
                I will try moving the slider to the center of the rail, and let you know if that does the trick.
                Have fun...
                Dik
                  CPhillips
                  Ok. I took a long look at it and I am somewhat stumped. Its not the joint placement that is the problem. It isn't connected right. But for some reason I cant seem to figure out how to connect it. πŸ˜„ I'll take another look tomorrow.
                    Dik Harrison
                    I took your advice and moved the slider to the middle of the rail. The result is a great improvement, but still a little sag/sink into the rail.
                    Much better.
                    Lesson learned, always attach sliders to center of desired travel range.
                    Latest version of file.
                    Thank you for you time and effort. It never dawned on me that distance from the slider would have this kind of effect.
                    Have fun...
                    Dik
                      Dik Harrison
                      Just looked a little closer and discovered that the problem seems to be the unbalanced mass of the traveler/slider/sub-base combination. The left side, which has less mass, sinks less than the right side, where most of the mass is. This is a problem because I will be adding a router to the sub-base, which will greatly increase the mass of the right side.
                      Left side.
                      The left side has almost no sinking.
                      Right side.
                      While the right side has the sinking effect.
                      I tried moving the slider to the right, closer to the center of mass, with no change in the sinking. I would expect that the unbalanced mass would cause the left side to raise rather than the right to sink.
                      Have fun...
                      Dik
                        CPhillips
                        [attachment=1:2gfxrqbb]<!-- ia1 -->PBB-2550_SRKltSide (800 x 526).jpg<!-- ia1 -->[/attachment:2gfxrqbb]
                        [attachment=0:2gfxrqbb]<!-- ia0 -->PBB-2550_SRKrtSide (800 x 526).jpg<!-- ia0 -->[/attachment:2gfxrqbb]
                        You could try using 2 sliders one at each end.
                        But I still think there is something about the way it is connected or shaped that is causing the the thing to sink. Not sure what tho.
                        BTW I was going to mention that you can make it a bit more stable and realistic if you adjust the Accel and Damp on the joints. Values of 0.0 mean it is unrealistically strong. Try something like accel=20, damp=15 for strong and slow.
                          Dik Harrison
                          Is there any place I can find documentation on how these settings work?
                          Have fun...
                          Dik
                            Dik Harrison
                            I have another drawing that has the same problem, the wheels of the cart sink into the SP solid floor about 1.5" when SP is run. I'm beginning to wonder if there is a scale problem, all of my stuff is drawn to 1:1 scale. I have seen that many SU users draw things way too large (i.e., not to scale). Or it appears so when I import their components from the 3D Warehouse. Am I missing something here?
                            SP off.
                            SP on.
                            The file...
                            Have fun...
                            Dik
                              CPhillips
                              Accel is how hard a object will rotate. With a hinge or servo it is about the same as torque. Damp is about the same as friction.
                              You can fix the latest model by going in and grouping the geometry in the wheels. Because it isn't grouped SP cant see it.
                                Dik Harrison
                                I hate that I'm being such a pain about this, and I apologize for the hassle, but I really, really like SP and want to use it making animations, and developing/designing my various projects and ideas. It makes these tasks several quantum levels easier and quicker.
                                Exploding the caster components and making them groups didn't work, I guessed a proper "mesh" was not created. So, I created SP wheels for the caster groups, and the problem was fixed. Lesson, make things with SP or they might not work as expected. I had tried adding a SP box to the rail in the other file, but that did not help.
                                There is now another problem that I had not seen before. Prior to the edit, the sheet of plywood lay on the table as you would expect (See the previous file). After the edit, it doesn't lay on the table, but moves to vertical and then stays at that same angle to the table, until it returns to vertical, at which time it falls off to the other side. In an attempt to fix this, I made a new sheet of plywood using an SP box, to no avail. What could make the sheet of plywood object act in this way?
                                Latest version, sinking fixed, but new problem.
                                Have fun...
                                Dik
                                  CPhillips
                                  Part of the table surface is marked as default shape. But it isn't aligned correctly. Try setting the readback collision features on the readback menu.
                                    Dik Harrison
                                    Thank you, I deleted some of the hidden structure and that fixed the mesh. This has all been very educational for me, I hope I won't have to bother you anymore.
                                    Have fun...
                                    Dik
                                      CPhillips
                                      No bother at all. Questions are always welcome. This thread acts as additional documentation and an examples. πŸ˜„
