    Custom Part Creation
    31 Posts 5 Posters 3.9k Views 5 Watching
    • W Offline
      watkins
      Dear Fred,
      Seems a simple enough shape for a CNC milling machine.
      If you want something quick but sturdy, then have it machined out of a structural plastic, such as an acetal homopolymer (see http://www.bayplastics.co.uk/acetal.htm). A ball cutter would make short work of the hemispherical sockets, and the whole thing would be straightforward to program into a CNC machine. Better still get, someone to model the item in SolidWorks, Inventor, Pro/E etc and then export using the correct file format so that it can be imported directly into the CNC's software.
      You don't show dimensions, but stock sizes for acetal go quite large.
      Regards,
      Bob
        remus
        Just a quick question fred, is this a piece for your TIN roof structures? or perhaps some other swanky new project our working on?
        • F Offline
          fbartels
          Jason and Bob... Thanks for your suggestions. Helpful and appreciated. Bob, any thoughts on who might be willing to model this piece in one of the programs you mentioned? I'm on a Mac and I think all those programs are Windows based.
          Remus... This is a prototype hub piece for my TIN roof structures.. nothing swanky. ๐Ÿ˜„
          Fred
            remus
            Theres bound to be someone on here whod do it for you, just got to wait for them to reveal themselves.
            If that doesnt work you might have some luck asking the machine shop to model it up, it doesnt seem to be to complicated a piece, and anyone whose got a reasonable amount of experience should be able to knock it up fairly quickly.
            • W Offline
              watkins
              Dear Fred,
              Would you be happy to post the skippy on the Forum? No need to dimension the model.
              What do you have your units set to - Metric or Imperial?
              Regards,
              Bob
              • F Offline
                fbartels
                Bob,
                Thanks for taking a look. It's attached to the original post in this thread.
                Units are imperial. We are stuck in the mud here in the States.
                F
                • W Offline
                  watkins
                  Dear Fred,
                  Would you please check the dimensions of the attached model, which seems to be slightly different from yours. The original and the Inventor model (which is which) should be obvious (view with hidden geometry switched on). It might be due to the fact that Inventor exports with circles set to 40 line segments and so there is a visual difference. The screenshot shows the geometry for the hemispherical features. The dimensions shown are in mm.
                  Regards,
                  Bob
                  Export from Inventor11.skp
                  • F Offline
                    fbartels
                    Bob,
                    Thanks so much for taking the time to help with this!
                    I believe, after comparing the two files, there was a problem with my original file in the sockets not being perfectly centered on the sides. If you take a look at the attached file you will see that in your model (on the bottom) the sockets are centered and in my original (on the top) they are not. Your version looks perfect!
                    Fred
                    shapes comparison.skp
                    • W Offline
                      watkins
                      Dear Fred,
                      Okay, I will post the model tomorrow in a few file formats so that you can chose which one to use.
                      Regards,
                      Bob
                      • W Offline
                        watkins
                        I have tried to upload files with different file extensions, but the system won't let me.
                        Could you send me a personal PM please.
                        Thanks,
                        Bob
                        • W Offline
                          watkins
                          Dear Fred,
                          Here are the files in zipped format. The .ipt is the native Inventor file type. The others are typical file types for export/import into other CAD systems.
                          Hope this helps.
                          Regards,
                          Bob
                          Fred's part.zip
                          • W Offline
                            watkins
                            Here is the .stl file. I have had to zip it in a folder as the Forum tells me that the extension .stl is not allowed.
                            Regards,
                            Bob
                            File for Fred.zip
                            • F Offline
                              fbartels
                              I'm working with a rapid prototyping service called Harvest Technologies (and Bob's model of the part) to make two copies of the part out of a Nylon/Glass-bead composite material. They are charging me $85 per unit for a total of $170. Since I'm new at this I'm not sure how this compares to other options (in particular to using a local machine shop with a CNC cutting device). The person I dealt with at HT was very helpful and took the time to answer all my questions. The parts should arrive next week and I'll provide an update with pictures then.
                              As always, any advice or suggestions much appreciated.
                              Fred
                                remus
                                Looking forward to seeing the pictures. Oh, and when are you going to start building a house? ๐Ÿ˜„ cant be long at the rate your currently going...
                                • F Offline
                                  fbartels
                                  Remus... no house building for a long time ... if ever. This is still in the nature of a wacky research project.
                                  Anyway, while I'm waiting for the prototype hub parts to arrive I thought I'd get to work on the socket and "spoke" parts. After getting a little nervous regarding some of the health issues related to working with PVC I've switched to bamboo for my spoke material. This was always my long-term plan but my miniscule research budget made PVC more appealing until the health concerns overrode the cost concerns.
                                  I'm working with 1.5" diameter (roughly) bamboo. In the ends of the bamboo sections I'm glueing 1" diameter dowel lengths in which I've drilled a hole for 1/4" threaded rod. On one end of the threaded rod I've glued a 1" diameter wooden ball which will fit into a socket in the hexagonal hub part (in theory). The threaded rod is used so that the length of the spoke can be adjusted.
                                  I'm trying to use materials that are inexpensive and might be readily available in a third-world country, with the exception, currently, of the hub part. I am trying to get a hold of some Ductal primarily to use as a roofing layer, but I also think it might be possible to use Ductal to make the hub part. If that is possible then all the parts could be made or purchased locally wherever bamboo can grow.
                                  As always, comments and suggestions and fellow collaborators are welcome.
                                  Some pictures of the socket/spoke parts.
                                  • F Offline
                                    fbartels
                                    So after two days of not being home to sign for the FedEx delivery I finally received the parts from Harvest Tech today. For some reason my initial reaction was that they were smaller than I was expecting but they are in fact perfect (thanks again to Bob Watkins for creating the CAD file). The next step is to make some molds from these prototypes and see if I can reproduce the parts using Ductal. I found what I think is just the stuff for making the molds from Areo Marine Products.
                                    • W Offline
                                      watkins
                                      Dear Fred,
                                      Glad to see that it all worked out.
                                      Regards,
                                      Bob
                                        remus
                                        Yeah, looks very good. Keep us posted.
                                        • W Offline
                                          watkins
                                          Dear Fred,
                                          You can also buy off-the-shelf plastic balls:
                                          http://plasticballs.com/delrin.htm
                                          For my development model I would drill and tap the plastic ball to take a wire-thread insert (http://www.emhart.com/products/helicoil.asp). The insert would increase the durability of the thread, making stripping out less likely.
                                          A production model might use moulded-in fittings (for example http://www.anchorinserts.co.uk/)
                                          A one piece moulding (ball and attached arm) might also be possible.
                                          Regards,
                                          Bob
                                          • F Offline
                                            fbartels
                                            Bob,
                                            Thanks so much for sharing the leads!
                                            Since this "system" is open source I hope that you and others will be interested in trying your own variations on the theme. One of the cool things about the system is that it is scalable. When I first got interested in TINs I thought they would make a great building toy and still do. In this entry to the Buckminster Fuller Challenge I tried to make the argument that a TIN building system (or toy) would help people think outside the box. (BTW, there are a lot of interesting design proposals on the BFC pages.)
                                            I'm focusing now on a version that could be implemented with inexpensive materials by local craftspeople, but that is just one of many possible paths to explore. If anyone is interested I would like to consider working with a few people to develop a proposal for the 2009 International Development Design Summit.
                                            Fred
                                            • 2 / 2
