Question about position in space of an object
I've been looking but couldn't find any method that can supply you with this information. If I add an object to my space, for example an object from the 3d warehouse, and I need to know its position in 3d space (ie, its coordinates (x, y, z) ), is there a method that does this for me? How can I do this?
I can't imagine there not being such a function. If I move an object to say (100, 200, 300) through the ruby console, that coordinate I assume should be somewhere present in the object's information. If anyone can help me I'd really appreciate it.
This is obtained through the object's transformation.
Could you be a little bit more precise? I've looked in the transformation class, and see a method that returns the x-axis, y-axis and z-axis vector. I am just looking to get a certain entitie's coordinate. A function that returns it's 3d position.
See if transformation.origin returns the result you are expecting.
Bender,
For coordinates, you can use Jim's Query Tool (QueryToolbar.rb).
Search for QueryToolbar.zip !Cornel
thanks! That seems to be what I need.
Bender
