    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Water House Part II
    7 Posts 4 Posters 4.3k Views 4 Watching
    • EddyNLE Offline
      EddyNL
      http://img181.imageshack.us/img181/8842/78627768iu7.jpg
      http://img141.imageshack.us/img141/4080/34969843ip8.jpg
      http://img181.imageshack.us/img181/4531/64196971sh5.jpg
      Working on a new design for a house near the water.
      Gotta go now to get some groceries or my girlfriend will kill me.
      More details will follow.
      viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
      • EddyNLE Offline
        EddyNL
        Back again.
        The living room and seating area are on the ground floor with a nice view of the lake.
        There is an open staircase leading to the first floor. First floor with a bathroom, and two bedrooms.
        The model is rendered in Kerkythea with a global sky and water material.
        House is still under construction. I need to add a few more rooms etc.
        P.s. This is the first version of the Water House:
        http://img403.imageshack.us/img403/8025/11qo5.jpg
        Comments, feedback welcome!
        Regards,
        Ward
          bubbalove
          Ward... I would suggest a different water texture or bump texture for the water... something looks funny. I see that you are using the globals from Kerkythea... they are great however some of them tend to over power the image IMO... so try to pick one that compliments your scene. I like the design and once you get a few things ironed out it should be a spectacular rendering!
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            rcossoli
            eduardo very well, looks much progress in your work, I especially like the texture of the stones, maybe you'd have in your interiors that use other components of higher quality than those that brings SketchUp, that helped a lot, greetings
            THREEDIMENSIONSWEB dot COM
              johnsenior1973
              Prefer the first water house.
              In WH2, I think the smaller windows should be the same white colour as the large windows facing the lake.
              How are the large windows going to open so that people can gain access to the balcony?
              Wouldn't building the house into the lake add massively to the cost of the building while not adding that many benefits??
              • EddyNLE Offline
                EddyNL
                Thanks for the comments guys!
                @ Bubba
                Can you help me out with some more global skies? I like to try some other ones.
                @ rcossoli
                The stone texture on the facade is from SU. I'll have to get some higher resolution textures.
                Thanks for your comment.
                @johnsenior1973
                I've changed the color of the smaller windows and added a sliding door so the residents can acces the pier / balcony thingy.
                Also I think you are right about the building costs on the water, so I've pulled the house back a bit.
                Got some new renders, hope you guys like 'em!
                Comments welcome.
                Regards, Ward
                http://www.don-eduardo.nl/Source/SketchUp/waterhouse2/6.jpg
                http://www.don-eduardo.nl/Source/SketchUp/waterhouse2/4licht.jpg
                http://www.don-eduardo.nl/Source/SketchUp/waterhouse2/7.jpg
                http://www.don-eduardo.nl/Source/SketchUp/waterhouse2/5donker.jpg
                http://www.don-eduardo.nl/Source/SketchUp/waterhouse2/8.jpg
                • EddyNLE Offline
                  EddyNL
                  Discovered the "walkthrough animation" in Kerkythea yesterday.
                  This is my first animation test. Scene has 481 frames, rendertime about 9 hours.
                  Kerkythea is great! ๐Ÿ‘
                  [flash=425,355:1ikyspob]http://www.youtube.com/v/tiHQZ3pOHcY&hl=nl&fs=1[/flash:1ikyspob]
                  Higher quality available here:
                  http://nl.youtube.com/watch?v=tiHQZ3pOHcY
