    Engineering Toolbox not working
    7 Posts 4 Posters 1.7k Views 4 Watching
    • EdsonE Offline
      Edson
      If you happen to fall under the Engineering, Construction or Facilities category, then please read on. We just found a new website that could be useful to you. Engineering Toolbox is a website dedicated to providing relevant basic information and data to the engineering and designing community. The best part about this discovery is the ruby plug-in for Google SketchUp; you can download standard and customized components like pipes, elbows, tee sections, lumber and beams. Download the Engineering Toolbox plug-in and use that welding neck flange you've always wanted.
      i found this info at the official google sketchup blo. i downloaded it and when tried to use it all i got is what you see in the attachment. would anyone know what is happening with it?
      http://www.mahfuz.arq.br
      • BurkhardB Offline
        Burkhard
        I had this with my video plugin. It seems it is a MAC problem with webdialog browsers
        [http://www.ia-plus.de(http://www.ia-plus.de)]
          marcosrodrigues
          Hi, Edson. It works (i use a PC) but in a "3D warehouse-like" way. You need to be online. Roll on the menu and click in the "insert" link.
          Oi, Edson. Testei aqui num PC e funcionou. Mas precisa estar online. E' so' escolher a peça que você quer que aparece um menu com as dimensões standard. Depois é so' clicar no link 'insert'.
          | menos é mais
          • EdsonE Offline
            Edson
            thanks, guys. it is definitely a mac problem (or rather, of not taking mac users into consideration). i tried it in windows under parallels and it worked.
              sepo
              Soory for digression but do you have the link for the toolbox.
              • EdsonE Offline
                Edson
                Home
                EngineeringToolBox - Sketchup Edition
                (sketchup.engineeringtoolbox.com)
                  sepo
                  Cheers Edson
