    Nullsoft Installer for Plugins
    10 Posts 7 Posters 3.0k Views 7 Watching
      tdev
      i created a nullsoft installer for sketchup plugins:
      it detects the sketchup installation directory and downloads sketchup if its not installed ๐Ÿ˜„
      sources: the nsi installer source. rename to .nsi
      should be easy to modify for your needs ๐Ÿ˜„
        Jim
        Thanks tdev, this is cool.
        For those who don't know - the attachment is not a plugin; it is a configuration file for the nullsoft installer which is a tool used to make executable installers.
        (I've split this topic from the "Installer" thread.)
          Baker518
          Jim, tell me how this works and how it will help, I have no idea I dont think
          Mike
          Don't worry about things you have no control over. Worry is a lack of Faith!
          • jujuJ Offline
            juju
            I think it will be of use to (ruby) developers as the end user won't have to copy files (scripts and such) to the SketchUp folders manually anymore, it will be automated.
            • jujuJ Offline
              juju
              Maybe collections can now be packaged together according to how appropriate they are to certain industries. Like having an installer package for architecture, etc.
                tdev
                nice to see you like the idea ๐Ÿ˜„
                and yes it is intended to be used by ruby developers to ease the script installation for end users.(But it can be used to install anything in fact)
                I just modified the winamp plugin example that ships with nsis into what you see ๐Ÿ˜„
                how to use:
                1. download nsis: http://nsis.sourceforge.net/Download
                2. put all your files you want to release into one directory
                3. download that installer script into that direectory and rename to installer.nsi
                4. modify the file installer.nsi with a text editor. Things you should change:
                Line 7: The name of the software you want to install. (Add version information):
                Name "Ogre - Sketchup Plugin 1.1.0"
                Line 53: What files to install:
                change the File command (see here for more info)
                  File *.rb
                  File lesser.txt
                  File readme.txt
                  File ogre_export.htm
                if you want to change the output path you can use this function.
                  SetOutPath "c;\"
                Line 73: The Instruction Website that is opened after the installation:
                  StrCpy $0 "http://wiki.rigsofrods.com/index.php?title=Sketchup_Plugins#introduction"
                Line 10: Determines how the result executable will be named (not such important):
                OutFile "ogre-skechtup.exe"
                1. after modifying the file, right click on it and select "Compile NSIS Script"
                i hope that helps ๐Ÿ˜„
                nsis has a lot capabilities, so lots of possible ideas for extensions...
                EDIT:
                Juju: the Nsis system can create categories for installable content, like you know "install full" or "install minimal" or select single categories, so everything possible ๐Ÿ˜„
                also if you want to adopt this for all ruby plugins, we should use a common logo and icon, so the user recognizes it
                  bianhai
                  Very good!Thanks!
                  • plot-parisP Offline
                    plot-paris
                    another competition!!! ๐Ÿ˜„
                      tdev
                      well, good luck with this, im out ๐Ÿ˜„
                        todd burch
                        I must have missed the Mac version. ๐Ÿ˜ฎ
