    [ruby doc] View.corner (bar?)
    4 Posts 3 Posters 963 Views 3 Watching
      Matt666
      Hi !
      In the doc, (view.corner index) returns a point3D. In reality it returns a point in pixels. 😞 😮
      Any solution to convert it in a 3D point ??? 😒
      Thank you !
      Frenglish at its best !
      My scripts
        RickW
        Not offhand, but I did update the docs at http://groups.google.com/group/SketchUp-Plugins-Dev/web/
        EDIT: Perhaps using a pick helper?
        RickW
        [www.smustard.com](http://www.smustard.com)
        • Didier BurD Offline
          Didier Bur
          I suggest you take the 2D point in pixels and use view.pixel_to_model to get the point in 3D where the corner of the viewport is, according to the current viewpoint.
          (Not tested myself, just a though).
          Salut Matt,
          EDIT: forget it, use pickray instead:
          "The pickray method is used to retrieve a ray passing through a given screen position in the viewing direction."
          DB
            Matt666
            Ok, thank you !
            It's so hard to play with screen dimension in SU... But I headed for solution !
            Thank you all !
            My scripts
