    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Cathedral(wip)
    6 Posts 3 Posters 627 Views 3 Watching
      Maximillian
      This is my current project. So far I only have over 1 week experience with 3d modeling, and a few days less with rendering so i would appriciate some pointers. ๐Ÿ˜„
      I started out by looking at a cathedral model, after several atempts i came up with one I was looking for. The I found a almost same much lower polly model(still low polly tho) which was exactly what I needed. The inside of the cathedral was empty, no benches, stained glass etc.
      FIRST RENDER
      http://img66.imageshack.us/img66/1213/41465545uw8.th.jpg
      SECOND RENDER
      http://img66.imageshack.us/img66/9342/69484521np9.th.jpg
      Moved the benches, added broken pipes/organ
      THIRD RENDER
      http://img61.imageshack.us/img61/7528/57577265ej9.th.jpg
      Moved the organ pipes around, added bricks/tiles to the fallen beam.
      FOURTH RENDER
      http://img61.imageshack.us/img61/9652/33804717ol6.th.jpg
      Added some "green" life to the image, and did minor texturing.
      FIFTH RENDER
      http://img61.imageshack.us/img61/2761/9wrongge4.th.jpg
      As you can see in this image, right at the doors there are pixels of light, which i cant get rid off and dont know what is causing it, i belive its the wood texture im using. If you know how to get rid of it, let me know.
      So thats all for tonight, im off to bed in a few minutes, have to work early, but let me know your opinions so far, and which light setting i should go for.
      Cheers, //av
        Hi Maximillian,
        First of all: what program are you rendering with?
        There should be some lights added (or use a different render preset) because to tell the truth, I cannot see too much of these images.
          Maximillian
          Im rendering with Kerkythea. And yes, I do realise there are light issues. I will try to solve those once Im back from work. For now i have been focusing on improving the model.
          http://img174.imageshack.us/img174/9572/13gq4.th.jpg
          If you dont mind pointing me in the direction of some good textures, Im in dire need for some.
          Cheers.
            remus
            That last image is looking pretty cool, keep up the good work.
            As for textures, have a look in the materials forum (components, materials and styles->materials), there is big list in a sticky at the top of that thread. Personally id recommend CGtextures, loads of really good textures, although there is a download limit.
              Maximillian
              I looked around for some preset textures, and found some on the kerkythea forum. Ill kee searching.
              And a little update. Im working on the brick out lining. Should be done pretty soon.
              http://img295.imageshack.us/img295/844/brick2nl6.th.jpg
                Your windows should also let some light in I guess. Change them to thin glass in Kerky.
