    LightUp
    25 Posts 12 Posters 3.6k Views 12 Watching
      AdamB
      @putnik said:
      AdamB, looks very interesting! Does it work in SketchUp 5? I couldn't find this on your web site (perhaps wasn't looking hard enought).
      Thanks.
      No LightUp only supports SketchUp 6 (and higher!) because to integrate with SU nicely it uses WebDialogs and Observers.
      Adam
        putnik
        Ok, thanks
        http://keshas.info
          Jorgensen
          I have tree quite simple questions i guess
          How do you walk around like in the Sponza building ?
          When I try to walk I loose the lightning
          Is the light included when one export as AVI ?
          Is it possible to export 2d images containing the lights in a heigh resolution ?
            juju
            Noticed that as well. I have the gravity switched on in the LU options and then navigate using that and scenes.
            Exporting animation with LU takes some time, the red line at the bottom of the screen is a progress bar (EDIT: just figured out it measures the time the demo has been loaded, once it reaches the righthand side of the screen SU locks up). Depending on your machine capabilities and the amount of scenes and lighting you have set you might want to go make yourself some coffee/tea/lunch/5 course meal while waiting. ... Oh lord it takes loooong, and I only had 3 scenes (using the LU studio skippy) to check the AVI export (and at a low viewport res at that!) so I can give you the correct answer. Sorry but the demo licence expired before the export finished. You know the demo licence only works for 30 minutes at a time then SU locks up.
            When you hit the enter/return button on your keyboard it takes a screenshot at 5x the resolution of your viewport. They're saved in TGA format and takes up quite a bit of space.
            Also have a look at the LU manual Adam put together. It's not complete by far, but it is quite useful.
              kwistenbiebel
              That's funny:
              "come on now...need to be fast here...can't think...how much time left?..let's export..and...zzzoing....time's up" 🤣
                Jorgensen
                Hi Juju
                Thanks for your very usefull information.
                It's strange that it takes long to export as AVI, does it have to render the light for each frame ?
                Jorgensen
                  AdamB
                  If you start the Tourtool and switch on Collision and Gravity you will be able to walk around buildings etc. It isn't the Sketchup Walk tool.
                  LightUp completely replaces the Sketchup rendering so functions that save screenshot of Sketchup won't work. LightUp currently only supports saving high resolution screenshots that can be sampled down to a useable size in a PS, PaintShop Pro etc.
                  Exporting movies from LightUp sounds like a useful feature for a future version though.
                  Adam
                    AdamB
                    At the risk of being a pedant, it doesn't "Lock up" Sketchup after 30 minutes. It times out and stops working but you can continue using SU as normal without LightUp for as long as you like.
                    Adam
                      juju
                      That's funny:
                      Yeh, laugh as much as you like KB, it was exporting the entire time until the demo time limit kicked in, and its not like I'm using a lightweight machine. Gathering from Adam's feedback, it looks like AVI export with LU scenes don't work currently. Probably why SU locked up on me then.
                      BTW, in his guide Adam warns about LU being capable of corrupting a model. The LightUp studio file I used with the above attempt to export had something happen to it, the model just completely disappeared after that little test run, so make sure you have a backup of the file as suggested by Adam.
                        kwistenbiebel
                        Sorry to hear it messes up your model.
                        As to .avi export: since LU is a baking app, doesn't it replace the textures with the new 'enlighted' ones? In that way, A .avi export should take the same time to export.
                        But I guess it doesn't work that way...
                          AdamB
                          I have to say I personally have never had a corrupt model from using LightUp. The only issue I've had - which sounds like what you've seen - is the model looking like its disappeared but its just the Layer is disabled.
                          I'm certain your model disappearing is nothing more than the Layer being hidden.
                          Adam
                            juju
                            And right you are again sir! Layer hidden by some phantom gremlin. This helps to set ones mind at ease, but that little disclaimer still gives me the chills.
                              AdamB
                              Its all very well you guys coming up with great ideas to improve LightUp, but I'm the one that has to write the code! 🤓
                              Anyhow, its done. For the retail version of LightUp you can now press Shift+return in Tourtool mode and it will save frame sequences in realtime which you can crunch down into a movie with Cinepac/mencoder or whatever.
                              Also fixed a bug in the current demo of LightUp (v1.1c) that prevented looping Animation working while in Tourtool, so that will be in the next release (v1.2a)
                              Adam
                              • 2 / 2
